Factory MAF Mod ?
  • Thread starter Thread starter 8994
  • Start date Start date Apr 10, 2009
8994
9
NH
Apr 10, 2009
  • Apr 10, 2009
I am looking to either remove the insert or hone out my MAF..
Never done this before..Any Imput?
vristang
4,933
101
124
Seattle
Apr 10, 2009
  • Apr 10, 2009
Your sig has 2 cars... which one?
Basically, don't bother... it will screw up the calibration and cause AFR issues...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 10, 2009
  • Apr 10, 2009
Save your time and energy, there are easier cheap ways to improve the MAF in your 89 Mustang.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs
built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange
on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box.
Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter Kurtz Kustomz Motorsports, Inc. KKM
Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
Try AutoZone and ask for 81413 - Spectre / 3 in. Aluminum Intake Mass Air Flow Sensor Adapter at $12.00.
You may have to order it online.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs.
You should be able to ignore it and have everything work good.
bubba-dough
1,044
Indiana
Apr 10, 2009
  • Apr 10, 2009
If you are wanting a cheap diy stock MAF upgrade do basically what jrinchker describes.
NstyLx
11
  • Apr 10, 2009
jrichker, I see that you have the 94-95 Cobra meter listed above as an interchange!! Being that they are 24lb. injector cars, was the computer calibrated to compensate or was the meter??
The reason I ask, I have a meter (F2VH-12B579-A2A) and the adapter already. Can I use that with 24 lb. inj. or do I need a calibrated aftermarket meter??
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Apr 11, 2009
  • Apr 11, 2009
you would need to get the computer also to effectively use the meter. if your tuning the car through the EEC though, it doesnt matter.
vristang
4,933
101
124
Seattle
Apr 13, 2009
  • Apr 13, 2009
The 94-95 Cobra ecu is calibrated for the 24's.
Ford did the injector calibrations in the ecu, which is the RIGHT way to do it. The aftermarket meter manufacturers actually skew the MAF output in order to compensate for the injector mismatch.
If you have an A9L and 24's, then you need an aftermarket MAF meter.
The above mentioned 70mm/F2VF MAF meter will only work with the A9L/A9P/etc ecu's when 19Lb injectors are used...
jason
NstyLx
11
  • Apr 13, 2009
jason
Thanks, I knew the 93 Cobra's computer was calibrated for the injectors and should have known the 94-95 cars were too!! At least I can use it for now until I swap injectors!!
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
For Sale Painless SBF fuel injection harness
  • 74delta
  • Aug 14, 2026
  • Other Classifieds
Other Classifieds Aug 14, 2026
74delta
