not to sure about your state, but mine does a visual inspection. They look under the car to make sure the car has them, then they throw her on the dino and sniff. Put the stock h pipe on, make sure your smog pump in on and works, make sure all vacume lines for smog are hooked up as well as the air tube. turn timing down and put 87 in the tank. I passed with flying colors. here were my scores:
NOx-standared 1378 Reading- 303
HC- standard-180 Reading-13
CO% Standard 1.01 Reading-0.00
as you can see, i could have probably had a non emmition cam in and still passed. i dont know why NJ nox readings are so high for my car, but ill take it. good luck
