Fake Hood Scoop ?
SANZ said:
Any suggestions greatly appreciated.
Hood Scoop Inserts :nice:
Black2K1 said:
I would like to find some way to make the scoop functional. I would be willing to pay a couple hundred dollars for a kit.
KarKraft use to sell that exact kit. There website doesn't show it anymore, but instead, they are pushing their Shaker Scoop (ala Mach 1).
You might want to check with KarKraft to see if they still have any of those kits still lying around.
Kar Kraft Engineering functional ram-air system for 1999/2000 Mustangs
Review of KarKraft Ram Air for 99+
I took the honeycomb off and drilled holes in it then I cut open the hood where the V6 insert is on mine that portion was fiberglass so it was pretty easy cut it with a dremel.
I then made sure to reseal the scoop with liquid weatherstripping so I don't have the problem with water marks on the hood. Now if I could just do something about the rear bumper and rear quarters from the C pillars.
damacman said:
Kinda' hard to believe that somebody hasn't come up with a universal kit to make the hood scoops on these cars functioning while retaining the stock scoop, hood, etc. It wouldn't have to be too complicated -- ram air from the scoop to the intake via some kind of flat aluminum ducting on the underneath of the hood. How many of you would buy a set up like this?
Here's some alternatives to look into from some research I did:
http://www.suncoastcreations.com/hoods_auto_99-up_mustang.htm
http://www.ramairhood.com/store/detail.aspx?ID=32 (Non functional)
http://www.classicdesignconcepts.com/catalog/itemdisplay/460.html
http://www.karkraft.com/ram_air.htm
http://reviews.stangnet.com/review.cgi?ID=213
Badd GT said:
last night a buddy showed me what he did with his.
he actually vented his to cool engine compartment.
he drilled every little hole completely thru.
then he cut holes in underside of the hood & cut a chunk out of his hoodliner.
pretty trick.
I like the looks of the hood, but also not a fan of it being non-fuctional. I'm surprised more newer GT owners have'nt tried to make their scoops functional rather than change the hood or go with the shaker. I'm not sure on the clearance between the intake and the hood, but would it be possible to mount a ram air box on top of the intake? It seems like it would not be too difficult. Cut a hole under scoop, run ducting from hole to air filter box, and remove the plastic grille in the scoop or drill holes. :shrug: If I had one I'd be tempted to try it.
Good stuff! After looking at all that has been built, I can't help but think that it might be as simple as using a BIG K&N square air filter like what fits in the 5.0 litre box stock (or larger). Then, fabricate an aluminum box to house it in with an intake funnelled into the inside of the of the stock hood scoop -- after you opened the scoop and cut a hole in the hood. Then, plumb all this to the MAF and finally into the plenum.
Anybody attempted anything like this?
Make sure you use some sort of water filtration/blockage if your build an actual working ram air. I think just porting the engine bay would have a positive effect.
I've been in the research of a nice hood for over a year before making my choice. Scoop, vs Ram air, vs ...
I loved the s281E hood look but it's not for sale. I went for the 03 cobra hood, it's actually a nice looking hood, cheap enough, and has functional reverse vents and agressive look!
whoa
i really like that pic
the deecals in the vent area looks really cool....
more pics??? side shots?
