SMOKEDYA said:Um i think it's your under drive's. Did you get the race or street one? They have been known to make a car run hotter then normal, because the water pump dont turn as fast. You could always get an electric water pump. i think the brand is CER? or something like that? It runs around $400 but is worth every penny! I dont have one but when i do the 408 i will! Kinda a dumb question but are you sure the thermostat is working on the fan properly or that the fan is even comming on? What kind of fan are you using? peace
john![]()
Thanks man,
The fan is "Torq Flo" and is run simply through a relay to the ignition, as the thermostat was giving me problems and in a hung over rage last saturday I ripped it off
So yes it's working, and from what I can see it works well, the car will idle around 180-190 and never get over that. But, if you drive it it will get hot which makes me think pump- but I'm not sure.
I really didn't want an electric pump, being I've got the efan and guages hooked through the ignition already and don't want to add anything else electric to it. I'm gonna search on mechanical pumps I guess
Okay... Here's where I stand and it's NOT very promising.
and will not drop at idle)
