fast idle / computer problems
  • Thread starter Thread starter danbot
  • Start date Start date Feb 19, 2006
danbot
taunton ma
Feb 19, 2006
  • Feb 19, 2006
i just installed an e cam and replaced the heads on my car(just stock iron heads)
after getting it back together i had a hard time with an idle surge. after reading the idle surge thread i saw that many people have idle problems with the e cam, and i did the iab mod. i then had a fast idle(around 1500-2000) i tried setting the tps and i got .67 volts and the highest i could turn it was up to .75 volts ( i know that .98 is the goal)
i am also having problems with pulling codes. i tried jumping the connector with a wire and it didn't work. i figured i was doing something wrong so i just went out and picked up one of those code readers from autozone but still nothing. i hook it up, key the power on and then switch the reader on and all i hear is a click than the pump cycles again then nothing( i watched it for like 2 mins)
the car is also running really rich
this is my first time trying to diagnosing problems with fuel injection
i tried searching but couldn't find any thing like this
any help will be much appreciated
-dan
vristang
4,933
101
124
Seattle
Feb 19, 2006
  • Feb 19, 2006
There are many others here who will be more helpful at trouble shooting your problem than me, but in the mean time I can help with the tps.
Sometimes you have to drill out the holes in the tps to get enough adjustability. Just don't get too carried away.
What is your fuel pressure at? I am assumig an afpr.
Good Luck
jason
joel5.0
429
Puerto Rico
Feb 19, 2006
  • Feb 19, 2006
The "can't access codes" situation....check the list of items to check in this fordfuelinjection.com article for that problem. Regarding the TPS check, I suggest not calibrating it yet, until you solve the codes access problem....a voltage/ground problem in the system might make setting the TPS now, a job that might need to be repeated again. LUK
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 19, 2006
  • Feb 19, 2006
Use a DVM to check for 5 volts on the orange/white wire on the TPS. No 5
volts and you have wiring problems.
Note that all resistance tests must be done with power off. Measuring
resistance with a circuit powered on will give false readings and possibly
damage the meter.
Next check the resistance between the black/white wire on the TPS and
battery ground. You should see less than 1.5 ohms.
Computer will not go into diagnostic mode:
With the power off, measure the resistance between the computer test
ground (black/white wire) on the self test connector and battery ground. You
If that checks good, remove the passenger side kick panel and disconnect
the computer connector. There is a 10 MM bolt that holds it in place.
Measure the resistance between the STI computer self test connector
(red/white wire) and pin 48 on the computer main connector.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
The following is a view from the computer side of the computer connector.
danbot
taunton ma
Feb 19, 2006
  • Feb 19, 2006
wow thanks for the info. i got the fast idle nailed down. i went back and reread the how to on the iab mod (i didnt disconnect the iab after modifying it) an just needed to grind it down a little bit more to raise the idle. the tps is set now also( i dont know what i was doing wrong)
i will look into the code issue tomorrow
danbot
taunton ma
Feb 20, 2006
  • Feb 20, 2006
ground and the battery ground was .4 ohms
the resistance between the STI connector
and pin 48 was .2 ohms
I tried self test again snd still nothing. Is this a computer problem or is there still something else to check
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 20, 2006
  • Feb 20, 2006
You got good readings, so your problem is not in the wiring. The only thing left is the computer itself.
danbot
taunton ma
Feb 20, 2006
  • Feb 20, 2006
sweet know were i can get an a9l cheep
thanks for the help by the way
you the man!!
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
