I would use at least 3/32" thickness for the cap, if by cap you mean the top of the outlet manifold. The real concern is how are you going to support the supercharger? If the case is moving forward 1`1/2" or so, some means of supporting the weight will have to be used. The 2.8LC is some 10 plus pound heavier than the 2.2 The stock inlet/outlet manifold plus the snout supports the weight of the supercharger. If the case is moved forward, some means of support will have to be fabricated. In our application, the top of the intercooler has a plate that is 3/4" thick that goes over to the supercharger top. This plate is what supports the weight of the case. There is a lot of load that goes through the supercharger at WOT, so I hope you take that into consideration.
It will be later this week before we take off the outlet manifold from the 2.8LC to be able to get you a blueprint. We cannot seem to find the original blueprint that was made.
Another thing that you can do if you are going to stay with the stock hood, if hood clearance is going to be a concern, is to space the K member down from the front subframe by at least 1". This in effect lowers the engine. You will have to look at other things like exhaust clearance ect, but at one point Walter had his K member spaced down by 2" until he bought the cowl hood. So that is an option to look at.
Post #66 on page 4 is wrong. The outlet manifold did have to be modified by a bunch to go from the 2.2 to the 2.8LC
