Progress Thread Father Time: Dyno'd 970rwhp
It was a fun 3 days or so, but now there's oil in the coolant and I need to figure out what's gone wrong.
I'm in the middle of a compression check. So far:
1. 151psi
2. I'm on this cylinder now. This plug is the most difficult to access. I've got the plug out and it looks fine. I'm having difficulty tightening the compression tester adapter in the plug hole and will go get a set of adjustable head ratchet wrenches tomorrow morning before I finish.
3. not done
4. not done
5. 122
6. 124
7. 142
8. 144
I don't like what I see in 7 and 8, and I'm not that experienced with blown HGs, but I'm fairly confident that if I took out a piston, the numbers would have been considerably worse. That's not to say that I'm certain I won't find a pleasant surprise in one of the last 3 cylinders.
The AFR went strangely lean today. I believe this to be the result of the engine missing and dumping the fuel and O2 from at least one of the cylinders into the exhaust. The BS3 is probably trying to compensate by richening the mixture. The mixture at cruise pegged out the O2 sensor at an incredibly rich 9.1:1. I'm pretty sure the BS3 is dumping fuel through those 120# injectors trying to get it back to the target, but because of the miss, no O2 is being burned in the cylinder. So no matter how much fuel goes in, the O2 sensor still reads O2 in the exhaust and interprets that as a lean condition. The only other explanation I can think of is that a fuel injector clogged or something's wrong with the pump.
I'll buy a couple drain pans and take a closer look at the oil and coolant tomorrow. The oil on the dipstick show no signs of coolant. At this point with the crazy readings I've gotten for AFRs and boost pressure, I'm hoping it's JUST a head gasket. This is all very tiresome after getting the best parts for the car and the best people to work on it. I wouldn't expect this to happen. I'm not ready to point any fingers or raise any hell. Was it the tune? Was it the build? Who cares? I just want a running, driving car with no major issues. Too much to ask, I guess, despite the time and $ invested. I'm probably just going to take the car to a shop in Atlanta and let them tear it down to prevent any hassle. I'm tired of this ****...
More to follow,
Chris
Drained the coolant. It is not oil! It is a bunch of rust and crap, probably from interior corrosion in the radiator, and rust in the block's water jackets.
I overreacted, and I apologize for that.
Chris
That's true.* It could be a headgasket, especially considering the cylinders are adjacent, but it would possibly be the rocker arm adjustment etc...* I'll do a wet-test soon, hopefully tomorrow.* That will tell me if it's the rings or something else.
120ish isn't good, but it is drivable there.
Chris
Edit (update):
The compression worked out to:
4. 144 8. 142
3. 146 7. 144
2. 150 6. 122
1. 151 5. 126
Chris
Good idea the wet test will help fill in the blanks... a little. If you take it to Proline, they are considered one of the best, your in good hands.
I had a blower car pump 145psi on nearly all cylinders, even the one that was missing 2" of land from the top of the piston:eek: Do a leak down test.....
Good Luck
Oh, yeah. I mentioned it in my compression test thread in tech, but the wet test did not significantly bring up the compression. It went from 126/121 in cylinders 5&6 to 130/125 or so. I think that indicates pretty clearly that the rings are not overly worn or the walls scarred due to some rich condition or "washing' of the cylinder walls.
I've got the valve cover off now, but am going to wait until saturday to do the work since I just started the Captain's Career Course. I'm busting my ass just to keep up with the assignments right now.
Chris
To clarify, the wet compression test showing a minimal pressure increase is a good sign. The rings and walls are much more difficult to fix than a leaky HG, or a hanging valve.
The work I intend to do on Saturday includes retorquing the heads to 110/100 ft-lbs, and then readjusting the rockers. And, if that doesn't fix the condition, then I'm moving on.
There are other priorities. The motor will run as-is.
Chris
I found the solution to a lot of the problems with my car. I wrote the guy who assembled the motor for me a message and instead of retyping everything, here's a copy/paste:
Mike,
Thanks for the response. I figured out the 1. fuel issue, 2. the boost discrepency, and 3. the problem adjusting the electronic boost controller. It all came from the same source: the vacuum hoses to the wastegate were loose enough to shift over while driving and touch the passenger-side header. One of them (to the bottom of the W/G) melted and created a hole that wasn't obvious without inspecting them closely.
Here's a quick lesson learned on that: don't use rubber hoses. Patrick recommended using some other type that I haven't gotten the details on, yet. Apparently it's a type of flexible polycarbon (plastic-like) that will not melt, and will not yield to heat.
How did it cause all of those issues at once? Try to follow me through all of this... it was confusing as hell working through the logic myself: The hose that ran to the lower wastegate also tee'd to the big-stuff 3. So, when it burned through it caused the boost to spike, while at the same time it caused the BS3 to read a lower pressure than the turbo was actually making. The hose to the upper side of the W/G was the one that ran to the EBC. So, the Greddy Boost controller was actually reading the right boost, not the BS3. At the same time, because there was no pressure to the bottom side of the W/G, and because the EBC can only adjust pressure to the top of the W/B, the greddy could not regulate pressure at all. The W/G remained closed throughout operation.
So, thinking through to what was actually happening: The boost was uncontrollably spiking to as high as the turbo could spin. The BS3 read a lower amount of boost (air) into the engine and therefore injected less fuel than was needed (extremely lean), and the EBC was not responsive to adjustment. Pretty much the worst possible combination of things you can do on a motor that's running pump gas.
The engine saw a max boost of about 23 psi at full load. Under partial load at low rpm it saw 30 psi!!! The fact that the motor is only showing minimal compression loss in 2 cylinders is amazing! Right now I should have a 300lbs paperweight of a short-block, and if I had let the turbo finish spooling it would've spun itself apart. I think I got out of the throttle quickly enough that I did not do any serious damage, and the compression check and the following wet-compression check seems to support that. At worst, my guess is that I burned the cylinder head between 5 & 6. Most likely is that it was a pre-existing condition with the gasket seal between the two cylinders. And, at best, the valves on those 2 cylinders need to be adjusted and it's just a coincidence that they happen to be next to each other.
The other piece to take away from all of this is using a vacuum tube (tree) to run all hoses in parallel instead of tee-ing everything in line. Even with rubber hoses, if everything were run in parallel, for example, the W/G hose might have gone out, but the BS3 would have reported the correct boost, and it would've been able to keep the mixture rich. Also, I would have instantly known what was going on.
More to follow,
Chris
Chris, I try to run individual sources when at all possible, especially when they are giving feedback to a boost controller or EFI system. If you have to, drill and tap the manifold so you do not have sources fighting for signal.
Glad you found that issue, it explains the non coresponding readings you had... I still use a lot of high quality rubber hose with no issues, I also run braided line at times as well. I'd be intrested to see what the "other hose is called.
The car is continuing to use coolant up. I did another compression test today. No change in the other cylinders, but the two low cylinders are even lower reading about 116psi each. I think it's time to pull the driver's head off and find out what's going on.
Oh, and I also pulled out the 13psi wastegate spring and put a 3psi spring in. That definitely explains why the boost was too high.
The other hose is called "push-loc" To me it looks like rubber hose with different fittings, but apparently there's a lot more to it.
I dont like the sound of that car eating fluid. It really makes it hard to work on a project when you know you have a big problem but cant seem to want to motivate to really get to it. I faught overheating for a year, hell last year I never drove my SC coupe b/c the problem.
I know one of my heads was leaking coolant where one of the head bolts goes in, and in the begining it would get sucked into the engine. Once we fixed that my life was better. Your problem sounds a bit more serous than that, keep us updated
how much did you drive it leaking coolant? did it leak into the oil pan, My old novi 2000 motor blew 2 head gaskets, and i didnt drive the car more than 10 minutes with the oil being contaminated and when i pulled that motor the bearings showed signs of contamination...
You ain't kidding. I'm in the Captain's career course and have so little time that it's a huge pain in the ass trying to fix these small issues. I really envisioned a drivable awesome street car after my performance shop having the car and almost a blank check for 2 years. I contacted the owner who I had a pretty good relationship with and asked him how he'd support me with the problem since its been using coolant since it came off of the trailer. He said that it wasn't using coolant and that the problem must've been in the tune. He told me to get the car back to his shop in OH (about a 10 hour drive) or that he'd help me get it there and they'd do whatever work I needed. After the difficulty getting the car back after so long, and given the leaks and poor attention to a lot of small details, I'm just not willing to send it back up there, again. They got the big things right, I think... The shortblock, the turbo-kit, the fuel system, the suspension. However, all of the small things, including things I haven't mentioned here, are just so dissappointing.
The amount of money, time, research, and thought put into this car is ludicrous, and I just wish I could drive the damned thing. It was sort of my dream after spending 14 months in Iraq that I'd come back, hop in the car, turn the key and go! hmpfff... Alas, nothing good in life ever comes easy.
I'll keep this thread updated when I figure it out. I'm trying to get in touch with Proline racing in Atlanta, who has an awesome reputation, but it's very difficult because it's probably 2 hours away from me and I'm going full-time right now. So, I just don't know how I'm going to get the car up to them.
I've driven the car a lot more than 10 minutes, but the coolant doesn't seem to be leaking into the oil, and it isn't leaking all that fast. I think it's just burning off in the cylinders. The head gasket isn't blown, and I'm guessing that your old motor was leaking coolant like a sieve.
I am a little concerned about the internals because I've seen metallic flakes every time I've drained the oil. I always cut open the filters. This last time the metallic flakes weren't too bad, but were still noticeable. I'm guessing/hoping that it's just typical engine break in. I've only driven the car a total of maybe 300 miles, but I've changed the oil 3 times just to keep a close eye on everything.
Chris
Chris
I feel for you man, ive got more money than i'd like to count into my car, it will all work itself out enevtually, and yea my gaskets were blown bad, the first time it blew it put the biggest cloud of white smoke out on the dyno ive ever seen. Kinda wish i had it on video lol.
I put my new motor on the engine dyno before it went in the car, and we took the filters apart and there were no shavings present, there was like little pieces of gasket but it was very minimal. My engine guy said you can expect to see some shavings in the first 20 minutes but he told me that my motor was exceptional and thats what he likes to see when the filter is apart on a Hydraulic cam. I'd watch those shavings if i were you, but it could just be the bearings taking thier seat
Hang in there buddy, I know where your at and the worst part is the last thing you want to do is drop another 2k in the car at someone elses' shop, but if you are where I was at you just dont care you want to drive the f'ing car. I moved in the middle of my build and the guy who was doing most of the work didn't move with me. I went to a speed shop up here and they were pointing everything out that they would do differnt. You need to tell them , like i did that you understand that every hop up shop has its own way, and that from now on you will only take it there so do what they think will make it run right. I did that and now Im happy.
My car runs so good I got pulled over in yesterday :banana: the cop was like WTF do you have under the hood, it sounds like a swarm of locusts flying down the street, he let me off with a warning I thanked him, then he started telling me how to merge with traffic, looked back at the car and said, "im sure you wont have any problems getting back up to hwy speed, john Force !!" I LOLed all the way back home
my theory is that your heads arnt sealing well, because of the lean/high boost issue. that can kill some **** fast, id take the top end off and inspect everything.. especially the flatness of the heads..
That issue is resolved, now. And I only got on it the one time that I noticed it. It's certainly possible that I did some damage, but the car was using coolant the first night that I drove it before the issue you mention.
GroverDill said:
I am sorry to hear of your troubles, I know how it goes. My car is sitting in the garage untuned still....
Thanks
89stang1 said:
Chris did u have a HC test will tell u if hydrocarbon's are present in the coolant? Good luck man!
Thanks for the tip. I've never done this test before. Do they sell this stuff at parts stores?
You're right, everything will work out eventually. I'm really looking forward to that.
That's exactly where I'm at right now... You hit the nail on the head.
My car runs so good I got pulled over in yesterday the cop was like WTF do you have under the hood, it sounds like a swarm of locusts flying down the street, he let me off with a warning I thanked him, then he started telling me how to merge with traffic, looked back at the car and said, "im sure you wont have any problems getting back up to hwy speed, john Force !!" I LOLed all the way back home
Awesome man! Would love to get my car to that point. One day...
Chris
John sent you a reply, sounds like the thermo is stuck shut....
Chris, you can buy a kit at most parts stores to see if exhaust is getting in your coolant system, some kits have an additive that changes color, some stores rent the system as well, or test strips. A pressure test should also show if there is an issue... How much antifreeze are you runing in your system? If you don't have enough it could be boiling and running out
Amazon.com: LISLE TOOLS 75500 COMB LEAK DETECTOR: Automotive
NAPA has one as well PT# BK700-1006 Combustion Leak/Block Tester is what they list it as
