few AOD questions
  • Thread starter Thread starter 68 & 00 GT
  • Start date Start date Feb 27, 2004
68 & 00 GT
2,407
HOUSTON TEXAS
Feb 27, 2004
  • Feb 27, 2004
First off -
The pan on my new AOD says Automatic Overdrive METRIC FORD
Metric WTF ?
Also, has anyone heard of Fairbanks Performance ? Had a sticker on it -
Lastly why does it have 3 different thickness shafts comming out where the stall / torque convertor goes on. There's a big one coming out of the center, with a medium size one comming farther out from within that shaft, and an even smaller, longer one coming out of that one ?
Sorry, I don't know anything about AOD's other than that ones going in my Stang lol.
Thanks -
12sec67
1,301
San Diego, Ca
Feb 27, 2004
  • Feb 27, 2004
mine says it too??? oh well.
oh yeh when you put your stall on make sure it clicks 3 times.
68 & 00 GT
2,407
HOUSTON TEXAS
Feb 27, 2004
  • Feb 27, 2004
makes me feel a little better. I trust the guys I guess I'm just paranoid -
Fairbanks Performance anyone - ?
bnickel
5,640
lubbock, texas
Feb 28, 2004
  • Feb 28, 2004
they all say that, apparently ford put that on there because when they first started putting AOD's in their cars was baout the same time that they started using netric fasteners in them as well, it was more of a warning to the mechanics than anything else, to let them know there were metric fastenets on it, IIRC anyway
DarkBuddha
2,215
Seattle & Tampa
Feb 29, 2004
  • Feb 29, 2004
Uh... http://www.fairbanksperformance.com/ Wooo... that was hard.
68 & 00 GT
2,407
HOUSTON TEXAS
Feb 29, 2004
  • Feb 29, 2004
No kidding. I meant more about reputation. Not if it exists
sand1man
299
Charlotte, N C
Feb 29, 2004
  • Feb 29, 2004
pretty sure the three shafts are there because it uses a lock up torque converter
DarkBuddha
2,215
Seattle & Tampa
Feb 29, 2004
  • Feb 29, 2004
Yeah, I coulda been more helpful, huh? Here's what I can offer: I've been looking into AOD shift kits and upgrades for a while, and Fairbanks' name always comes up, but not with any overwhelming endorsements. I checked the 5.0 forum and they seem to be pretty into the Transgo kits I think. Still, Fairbanks has been around forever, and I remember seeing their stuff show up in magazines over the years.
Regardless, if your AOD has a shift kit or any other upgrades, that's better than nothing at all, and the AOD can use all the help it can get.
68 & 00 GT
2,407
HOUSTON TEXAS
Feb 29, 2004
  • Feb 29, 2004
thanks
he seems to think it'll hold a mild supercharger, or turbo set up on my 302
WTF ! I got a 2,500 stall non lock up
corpse
2,562
chicago area
Feb 29, 2004
#10
  • Feb 29, 2004
  • #10
something to keep in mind, is the shift pattern of an AOD - which just stinks for racing.. To get into 2nd, you must shift 1st to 3rd and back to 1st - and your timing has to be right. This wasn't sufficient for me, so I went with a Lentech valve body, which makes the shift pattern 1-2-3. It has a solenoid in it that you can activate with a switch, that will automatically allow the trans to shift from 3-4 - while racing, this would be turned off - because shifting from 3-4 in an AOD (no matter how well prepared), is just a bad thing.
sand1man
299
Charlotte, N C
Feb 29, 2004
#11
  • Feb 29, 2004
  • #11
I hope for your sake I am wrong,trying to find out for sure
68 & 00 GT
2,407
HOUSTON TEXAS
Feb 29, 2004
#12
  • Feb 29, 2004
  • #12
so it's like the car shifts from first into third, and you have to manually downshift it from third back to 2nd ? Wait how do you manually shift from 3-4, and why not do it ? I'm confused. I thought it works just like a new AODE.
corpse
2,562
chicago area
Feb 29, 2004
#13
  • Feb 29, 2004
  • #13
I'm not sure how an AOD-E works, quite frankly, I forget
With the Lentech valve body, you don't shift from 3-4 manually, it will automatically upshift when you reach a certain speed/eng rpm (not sure what the criteria is). But because the bands or whatever for 4th are really week, you don't want any powerful shifts into that gear.
I did ALOT of looking into this, as I plan on racing my stang for fun in auto-x's n stuff - and that involves lots of 1-2 shifting.
And yes, to shift into 2nd, you must semi-quickly, but not too quickly, shift from 1st to 3rd back to 1st. My 92 t-bird is the same way (normal AOD in that car too).
And supposedly the circuits in the valve body are a different design to allow better lubrication, more consistency, yadda yadda Check it out at their site.. I got the Street Terminator (calibration 2). If I ever do another AOD, this valve body will be the 1st thing I buy.
http://www.lentechautomatics.com/aodhome.html
And no - I'm not a lentech sales rep - just real happy with how well that valve body works.
68 & 00 GT
2,407
HOUSTON TEXAS
Mar 1, 2004
#14
  • Mar 1, 2004
  • #14
ha ha.
Yeah thanks- I'm just surprised to hear of this goofy shift pattern in the AOD. If I just leave it in drive it'll go through the gears like normal though right. Guess I know what one of my next mods will be. I'll check out the current shift pattern and then see what I need to do. Probably go ahead and call Lentech and get the same valve body you have.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
Slow84LX's 1984 T-top coupe
  • slow84lx
  • Jul 14, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 12, 2023
General karthief
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
