first, what is the cheapest way to swtich to MAF on my 88 5.0?
second, what speedo gear do i need for my new 3.73's (i have a 5spd, i think i read that i should get 21-tooth)?
third, how do i install the speedo gear (where does it go? can i do this myself?)
fourth, anyone notice their inner shift boot not fitting properly with an mgw shifter? it seemed far to tight when i put it in, and has since then slipped off and is slideing down the shifter's bottom shaft
fifth, i bought some used 31-spline axles but they have "3 inch race studs"(i think) in them....so my question is what is the standard size of stud? so i can buy some new ones that are the right size
sixth, what are the best fluids to use on the diff and gear install? what kind of oil and friction modifier should i use?
thanks
-Travis
thanks
-Travis
) and then use the 10-holes for a set of slicks
