Zookepers exactly right.... it's easy to do, but do it in two parts.... prep with 80 grit on the bottom side and lay matting (either flexible or firm) soaked with resin, let it sit until it hardens, rough the shape out, the prep the top side and laminate the second "half" of the repair.... then you can shape the corner to match the contour of your headlight bucket. Once you've got the rough shape, you can use the short strand fiberglass filler to finalize the shape, and finally, polyester filler ( AKA-Bondo) will blend the contour into the rest of the hood.
Using cardboard wrapped in wax paper you can make a temporary mold or support that will allow you to shape and build the edge without it sticking. Be sure to sand any surface that comes in contact with the wax paper after words so you dont have any contamination issues with your primer.
Make sure that oyu prep the existing fiberglass with an aggressive tooth (80 or 40 grit) to give the new repair something to grab on to... this is probably the most important step.
Dont just build it up with filler... it will become brittle and right on the edge you'lre almost guaranteeing a repair that will break your heart.
Hope this helps!
KT.
