Well I finally finished my 94. It took a while with the usual delays... kids, family, work, money... Anyway, I put it all together at once (see sig) so I was amazed it started right up
It even idles ok after a little TB adjusting. It does hang at 1100 rpm after a good rev then settles down to 750-850. Not too bad without a proper tune.
I still need to adjust the timing (need to buy a light) I have one question about the valvetrain. With the TF Rockers I put in, is a little noise normal?? They have a little valve clatter it seems pretty even on both sides but I don't feel like opening the covers again to re adjust if it is not necessary. I used trick flow 6.75 pushrods with the TF trackhead heads and TF 1.7 RR 7/16 stud mounts. I went the recommended 1/2 to 3/4 turn after zero lash. I know this is hard to diagnose without hearing them but I figured I woud ask anyway.
Thanks
for all info in the forum guys it has been a huge help with my project. Whenever I needed to know somthing I came here first and usually found the answer.
It even idles ok after a little TB adjusting. It does hang at 1100 rpm after a good rev then settles down to 750-850. Not too bad without a proper tune. I still need to adjust the timing (need to buy a light) I have one question about the valvetrain. With the TF Rockers I put in, is a little noise normal?? They have a little valve clatter it seems pretty even on both sides but I don't feel like opening the covers again to re adjust if it is not necessary. I used trick flow 6.75 pushrods with the TF trackhead heads and TF 1.7 RR 7/16 stud mounts. I went the recommended 1/2 to 3/4 turn after zero lash. I know this is hard to diagnose without hearing them but I figured I woud ask anyway.
Thanks
