finally i should be getting my dyno numbers by the end of next week, maybe before if all goes well.
my builder has had the car 2 weeks so far. he has the engine put together with the 7 qt oil pan on there and the headers, he is going to drop that and the trans back in tomorrow. i know he has the bap and GT pumps in, and the intercooler mounted ( he just has to do the pipeing. the clutch and flywhel is being worked on. all he has left is the blower, all the piping, the 8 rib kit, and the maf and bypass valve. then we will heat cycle the engine, drive it about 25 miles and throw it on the dyno.
SO LETS HEAR THE HP AND TQ GUESSES!!!!!!!
here is the new mod list: (what i can remember)
Paxton novi 2000 blower
3.0 blower pulley
8 rib pulley set up
MPH boost pipe
a/c delete kit
Paxton a/a intercooler
#60 injectors
dual GT fuel pumps and wiring upgrade
KB bap
blow through maf set up
vortech mini race bypass
MPH 800 hp Aluminum block with ARP main and head studs
Morso 7qt oil pan
melling oil pump
Spec clutch
Fidenza aluminum flywheel
^ that will be added to what i already have
foxlake stage2 heads (comp springs)
miled custom stage 1 blower cams from foxlake ( 212-214@050/ 114 lobe center)
SLP long tubes
regular bolt-ons, exhaust and plenum/tb
3.0 blower pulley
8 rib pulley set up
MPH boost pipe
a/c delete kit
#60 injectors
KB bap
Morso 7qt oil pan
melling oil pump
Spec clutch
SLP long tubes
i guess
