Finally, my blower install
woodyy24
290
illinois
Its mostly done, i need to do a little rewiring and re-runing of the gas lines.
and i need to get some shorter crank bolts. my biggest problem is the accessorie belt tensioner. I had to cut the bracket to make way for the blower shaft. So i have to come up with some way to mount it elsewhere.
if i can get that done tomorrow ill have it fired up.
EDIT: the bracket where the tensioner used to be
fox racer said:
how about you set up some sort of turn buckle the attaches to a water pump bolt and to the upper Alt bolt. Similar to the March kit, that way you can amnually adjust the tension.
Looks good!!
I agree with the adjustable turn buckle idea...get a couple of sphericle rod ends, jam nuts and all thread and you should be set...attach one end to the alt, the other to the bracket and tension as needed.
Jim
grey5.0beast said:
very nice, whats the rest of the mods?
Jegs crate shortblock
E7s ported, 3 angle grind, bigger valves, springs
clevite cam similar to an E-cam
1.6 roller rockers
crane lifters
hardened pushrods
barry grant boost refrenced demon 750
high flow oil pump
underdrive pulley
MSD 6a, MSD dizzy, MSD blaster coil, MSD tach adapter
electric fan
holley blue fuel pump with regulator
cobra clutch
tremec HD T-5
aluminum driveshaft
3:73s
upper and lower control arms
airbag in passenger rear
edlebrock plate nitrous kit
pro 5-0 shifter
170 amp 3g alt
a/c delete
theres probably more too
edit: BBK equal length shortys, BBK o/r x-pipe, 2 chamber flows, 2.5'' tails
dual roller timing chain adjustable +or-8*
aero spindles and brakes
I was thinking, would an alternator bracket from an old 60s mustang work if i spaced it properly. that way i could just get rid of tensioner completly. something like this.
So did you decide to cut the hood, or does the air cleaner still clear? Gotta admitt I was lookign forward to seeing the black beast with a bird catcher looming above the hood. Looks great though.
It has to be cut the carb doesnt clear (probably because of the nitrous plate)
Im going with the bird catcher
