Hi there all :SNSign: members..
Well finally after a looong engine assembly and everything rechecked like 20 times before doing it i am ready to crank this baby on.
However i have a lot of "fear"
to screw things up, i have hooked up the tweecer ( what a nice nice hardware ) and reading eec and trying the datalog before the engine turn, its working flawlesly but i have to make a re-check before i turn the key on:
Well i think i have most of my mods on the signature however i will state them here again (at least the ones that concern the tuning) :
Ford Racing 30 lbs inj.
STOCK MAF ( i didnt touch the stock maf transfer )
Cobra upper and lower intake ported to match heads
AFR 165
BBK EQ. Length ( What a PITA to install and tight them )
EGR disconnected ( even the bbk had on them the output the stock tube dosn´t fit the intake and i dont have time to re-make the little bugger)
Removed Air pump
Aeromotive FPR ( 39 lbs )
Timming 13 ( i will have to rent a light or something to back out to 10btc)
180 t-stat
75 mm Throttle BD.
Well the installation of the tweecer is easy , but i havent figured out how to get the eec on its place ( i cant reach the screw holding the plastic retainer), so i have the eec laid down on the floor of the passenger side ( i will fix this soon as this baby starts to roar )
Well to the point :
according to the manual here i had maded some changes
The changes i had made to the tweecer are the following :
Scalars :
EGR System Type : 2 ( Disabled )
Idle in gear : 800 ( i will low this if the cam allows it )
Idle in neut. : 800 ( see last )
ISC Max. Drive RPM : 848
ISC Max Clos. Thr. idle : 900 ( as stated on here 100 rpms above idl in gear )
fan_high_speed_ECT1_on = 196
fan_high_speed_ECT2_on = 200
fan_high_speed_ECT_off = 190
fan_low_speed_ECT_off = 182
fan_low_speed_ECT_on = 188
fuel_injector_breakpoint : 1.98E-05 = .0000197589 ( this was as the tweecer manual said on the 30 lbs inj. )
Fuel_injector_min_pulse_width = 3.8147E-6 = 0.0000038147 ( same as breakpoint based on tweecer manual.)
injector slope high = 30.4994 ( tweecer man. )
injector slope low = 38.499
Thermactor Presen = 0 ( disconected )
Functions :
Injector Offset vs. Battery Volt. ( this was pulled from E.A. <- best tool ever)
volt : | 0 | 5.5 | 6 | 7 | 8 | 9 |
Adder: | 7 | 7 |4.6563| 3.0313 | 2.0313 | 1.5313 |
volt : | 10 | 11 | 12 | 13 | 14 | 15.938 |
ader: | 13.125 | .9375 | .875 | .6875 | .625 | .625 |
This are all the changes i made , to my thinking this is mostly the more relevant to start at normal and gentle idle ( hope so )
However i have questions on more things :
The manifold_volume_(liters) is set to "4" stock should i rise this to 5.5 as i have seen on some cobras??
The Trottle body Air Flow would be needed to be changed b/c 75mm ?
I have seen on the calcon the tps closed @ 1.1 v, i cant adjust it mecanicaly unless i drill it or something like that however the calcon reads fine the Closed,Part,WOT readings. should i let this as it is?
Lastly and no more less important , i cant afford the e.a. as of now ( i really promise i will buy it ) i just would like to know if any one can help me with the Injector Timing using the EA with the cam specs, ( 86GT "eectuning.org" i promise to bought your
EA
as soon as i have money )
Really Thanks to all for reading this Loooooooooooong post and any guidance will be gold to me as of now.
I hope this info ( if works well ) will help anyone there with the same combo or atleast whatever u can use from it i promise to post the CCF when i verify it works well.
to screw things up, i have hooked up the tweecer ( what a nice nice hardware ) and reading eec and trying the datalog before the engine turn, its working flawlesly but i have to make a re-check before i turn the key on:Well i think i have most of my mods on the signature however i will state them here again (at least the ones that concern the tuning) :
AFR 165
Removed Air pump
180 t-stat
75 mm Throttle BD.
Well to the point :
Scalars :
Functions :
EA
as soon as i have money )Really Thanks to all for reading this Loooooooooooong post and any guidance will be gold to me as of now.
about it now
