Did a bit of a search, but since this isn't a problem it probably hasn't gone across anyone's mind.
I've heard different lumpy motor idles, and some sound chaotic, like a random idle, and some sound sorta like a harley, fire fire skip skip fire fire but with a V8 it's like all the cylinders at once, then a little gap, repeat.
Is it just different cam grinds that can give the same motor a random idle and a lopey (I guess) idle? I think the random stuff is extreme cam, built for astronomic revs, but I thought a less aggressive cam would just give a smoother idle, not a trump trump trump.
Also, I guess the plenum intake harmonics come into play with this, one cylinder sucking the gas one way, perhaps starving the next to fire if it is at the other end. I suppose that IS why lumpy cams sound lumpy.
Gawd I hope someone understands and wants to talk about this lol. Describing sounds in words isn't the smartest thing to be doing, but I guess it's not as bad as actually trying to make the sounds.
