update, went back took off the mani, replaced the gaskets and sealed it all again. Changed the oil, still leaks. somehow my dizzy is stuck in my motor...mitchcj1 said:Any progess? Im in the same kinda situation and ran into this... My car would only idle at fully advaned timing. Meaning the radiator hose wouldnt let it go further. The guy who runs the garage where I keep it had me move every plug wire on the cap over one position, thus retarding it however many degrees. That pretty much did it. the timing can now be adjusted throughout the normal travel of the distributor and I was able to let out the idle screw to keep a much lower RPM going at idle. So is this just a quick fix for a bigger issue or a viable solution?? Thoughts??![]()
