Questions...
How many miles?
Will the fan turn on all on it's own or will it run hot with the switch off?
High idle could be many things. First, check for missing or broken vacuum lines. Listen for hissing noises while the engine runs. If no vac lines are broken..missing or disconnected, you may have a bad Idle Air Control sensor. The IAC sensor sits on the very top of the throttle body. Unplug the electrical plug on it... if the idle drops a ton after disconnecting, the sensor is most likely bad. No problem, these are easy and inexpensive to replace.
Scraping noises with 2 or more people? What size rims and tires does it have? If they are too large, the front may scrape with too much load. If thats not the cause, then the front springs may be worn. Try pushing down on the front end of the car... does it go down a lot? How much does it go down when you get in? Depending on the mileage, the springs may or may not be worn. I do find that hard to believe tho. My 96 has well over 140k miles and the front springs havn't gone south yet. It does lean a bit more on turns but I dont expect top performance from aged springs.
For the check engine light, I wouldn't worry. It may have to do with why the engine is idling so high. Go to an Advanced Auto Parts and have one of them come out and connect a scan tool. They can pull your codes for free.
$1700 isn't all that bad ...for a 94 convertible V6. Depends on the mileage. You will have some problems. For that price, you can't expect a perfectly running Mustang in top condition. The problems you are having are cake. If the springs are indeed worn that bad, then you will be paying for a shop to install new ones, unless you wish to do that yourself. Don't fret man..
