first car. so many problems.
94mustang0886
14
Hey there i have a94 mustang convertable ,automatic. i bought for 1700. thinking it was a good deal, runs but convertable top is all tore up. paint is ok., and the check engine light stays on , they guys has an external fan switch for it. seems to run ok but the dang idle is to high and i cant seem to lower it what could be the problem. and also the front scrapes with 2 or more poeple which i didint know becuase i had nobody else with me when i bought it. any ideas to fix problems and did i just get ripped off?
Questions...
How many miles?
Will the fan turn on all on it's own or will it run hot with the switch off?
High idle could be many things. First, check for missing or broken vacuum lines. Listen for hissing noises while the engine runs. If no vac lines are broken..missing or disconnected, you may have a bad Idle Air Control sensor. The IAC sensor sits on the very top of the throttle body. Unplug the electrical plug on it... if the idle drops a ton after disconnecting, the sensor is most likely bad. No problem, these are easy and inexpensive to replace.
Scraping noises with 2 or more people? What size rims and tires does it have? If they are too large, the front may scrape with too much load. If thats not the cause, then the front springs may be worn. Try pushing down on the front end of the car... does it go down a lot? How much does it go down when you get in? Depending on the mileage, the springs may or may not be worn. I do find that hard to believe tho. My 96 has well over 140k miles and the front springs havn't gone south yet. It does lean a bit more on turns but I dont expect top performance from aged springs.
For the check engine light, I wouldn't worry. It may have to do with why the engine is idling so high. Go to an Advanced Auto Parts and have one of them come out and connect a scan tool. They can pull your codes for free.
$1700 isn't all that bad ...for a 94 convertible V6. Depends on the mileage. You will have some problems. For that price, you can't expect a perfectly running Mustang in top condition. The problems you are having are cake. If the springs are indeed worn that bad, then you will be paying for a shop to install new ones, unless you wish to do that yourself. Don't fret man.. :)
aww thanx man you making me feel beter!! i love U! i was stressing over here becuase my parents bought it for me i didint want them to regret it. so i will check the aic tomaro . but right now i checked the tired and they are not hitting.!!!! anything at all!! but i still hear the scraping! wierd what could it be?? but yeah it has over 200,000 miles . and also the guy ssaid he put the direct switcch to fan becuase it would shut itself over probly due to that aic problem you talking bout you think??
The fan has nothing to do with the IAC. Let me try and interpret what you meant here. I assume you meant the guy put the switch on because the fan constantly runs without ever shutting off. Is this correct? Or do you mean it turns off and never goes on? In either case, a switch is "OK" for some techies like myself, but for many its a problem. IF the switch when OFF totally disables the fan circuit and does not let the engine PCM control it, then that is a SERIOUS problem. I am not sure how this person wired the fan switch up. It could be a direct bypass which would cancel out engine fan control or it could just be temporary meaning that the engine PCM still has control over the fan circuit but the switch will let you turn it on anytime. If this is wired as a direct bypass, the engine PCM (computer) would never have control over the fan and can easily result in overheating because you would have to constantly monitor the temp gauge and turn it on when it got hot. Leaving the fan on all the time can actually waste gas. Because the fan is overcooling the engine. I would have to see the wiring to see what this guy actually did. Chances are he wired it like that because either the fan relay is going bad or the engine coolant temp sensor is faulty (which would trigger the fan if it thought the coolant temp was constantly high).
well i can take some pictures tomaro. but i whent to a junk yard today and picked up a ford iac and plugged it on my stang AND IT WORKED !! no more idle problems! thanks ! buttt..... now my mph gauge dosnt work ?? also the iac plugs on backwards, it faces opposite direction that the other iac. could that be the pjroblem. and also ya i think he plugged fan directly to switch without going through the computer kuz the wires seeam like they are going strate to the switch. also could the fan be reason car says check engine?? also on top of all those problems do you know whart the scrapping problem could be kuz i checked all tires and they do not hit any part of body at all, what could be making a scrapping sound similiar to that??? im stumped. oh and thanks man for helpping a newbie so much:D.
