First dyno numbers for GT40 setup
lager94GT
119
LI, NY
I just had my car dynoed for the first time. Mods are in my sig but, in general, I have an E cam with GT40 iron heads and cobra intake. I bought the heads used from Stangnet a few years ago and was told at the time they were ported.
276 rwhp/313.8 ft-lbs torque
The A/f is rich. It fluctuated around 11.5. This could be because I run the ACT sensor in the fenderwell. I have the PIH kit with A9L computer. The cobra lower doesn't have the tap in the #1 lower intake for the ACT sensor.
Wow those are nice numbers for your set up. I may need to buy my brother's iron GT-40 heads and his E303 cam.
Are you running stock injectors? Only reason I ask is because I just bought a PRo M MAF calibrated for 19's and I wanted to know how much power the stock injectors can support. thanks,
I have 24lbers with a 76 C&L MAF, 190 lph fuel pump and afpr which I guess I'll start playing with to lean it out a little.
RIO5.0 said:
Those are good numbers....I have damn near the same set-up...I opted to stay with 19 vs swapping 24s...Makes me think I left some ponies on the table??? your like 14 Hp more than I....Oh well...add them to the Winter list... :D at the time I didn't feel like sending my Pro 77 back for recal...
So how much does it cost to recal the Pro M MAF's? I'd like to stay with my 19's for a while but I know someday I'll need to upgrade.
It was 115.00 shipped for my Pro-77....
My AFR on my last dyno was still sweet...the thinking was the AFR will dictate when your maxxing the 19s..I went with that thought...
Was also leary of EEC issues as I still run the stock computer...Sometimes its a crap shoot with SN95s....
*OFF TOPIC*
I'd really like to see more pics of your car in your avatar if that is indeed your's, either or, post up. :D
mystang94gt said:
check page 4 of the Best looking stangs by color thread he's got a few in there. His is one of my favorite SN95's from stangnet.
Thanks Gents....I need to get 400HP into it now... :D
T_5.0_N'works...I added some pics in the above post for ya, since its pretty much spent...
Those numbers are VERY respectable for iron heads and an E cam. Sounds like the combo is a good match. You can always try a Pro M Optimizer to lean out the mixture.
I will swapping in the PIH kit next month and just ordered a Crane Hi6 ignition. Where did you mount the ignition box? Any tips on the install? Thanks
