Fitting 10th Annversary Cobra wheels
xherdlr
159
Hendersonville,Nc
I just bought a set of 10th Anniversary wheels 17x9 with 26mm offset. I mached up the rims and noticed fitment issues. I have SN 95 front and Ranger axles in the rear. How did you get them to fit? Also,what tire size did you use?
Kelly
You shouldn't have a problem. I'm running 03 cobra rims and have zero fitment issues. 95 spindles, stock length 5-lug axles. 245/40 up front and 275/40 out back. Where is the fitment issues?
Rubs the quad shock... I dont have tires on the rims yet. I have 4 245/45/17s. I havent checked the front..Im on nights and Im geting ready to leave for work.. Ill check the front in the morning. Im also not sure that my tires will work....
Kelly
I have aftermarket upper and lower control arms and ditched the quad shocks. I have some slight rubbing in the front due to the size but its to be expected. I have the same setup and you should be alright with the quads flipped.
I just put the anniversary wheels on my 93 gt yesteraday. I used the lsc rotors up front and had to put a 1/4 inch spacer to make the wheel sit flush against the rotor. In the back i used stock size five lug axles in the back. I took the quad shock off and have no rubbing problem in back. I used 245/40 up front and 275/40 inthe rear cause im going to lower the car to. The only problem i have is that the center cap wont fit on the front wheels. Any suggestions?
he means you have to do something like this
I would Flip the Quads, NOT ditch them! You can get a set of rack limiter CHEAP from any Ford Dealer and that should stop the rubbing up front!
I have a similar setup and also was going to order 10th anny wheels. When you guys say there is a little rubbing where is it. Is it on the fender lip or on the inside of the wheel. I was planning on using 96+ spindles but don't wanna if they are going to rub even more. SOrry for the HIJACK -Deece
