Fixed e break.. Now brakes are locked up..
  • Thread starter Thread starter billison
  • Start date Start date Nov 21, 2012
  • 3
  • 4
First Prev 3 of 4 Next Last
tca7291
I can see your wieners.
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 22, 2012
#41
  • Nov 22, 2012
  • #41
Sorry, shoes off...
Maryland Stang
1,656
30
39
Greenville, NC
Nov 23, 2012
#42
  • Nov 23, 2012
  • #42
Don't touch the brake pedal with the drums off. You can play with the E brake all you want.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#43
  • Nov 24, 2012
  • #43
ok, thought I'd give an update. I've replaced the drivers side cable and started adjusting the brakes. The ebrake now works. I've not driven the car yet. I still got a bit more adjusting on the brakes to do, i'm not really sure what i'm looking for as far as how tight to get them, i've mainly aimed for them being even at this point. any advise here? Like with the rear end in the air should it be strong enough to kill the engine? The book just says get them where they start to drag a little them back it off a bit.
I'll be doing the other side soon, but for now it works. the car is not being driven, so no worries, i'll make sure it's right before it gets driven.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#44
  • Nov 24, 2012
  • #44
ok, my buddy told me about the self adjusting if you drive in reverse and apply the brake. this worked like a charm!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Nov 24, 2012
#45
  • Nov 24, 2012
  • #45
I've always tightened the star wheel until the wheel is hard to turn (to center things), then back off the star wheel until the wheel just spins freely. The brakes shouldn't be dragging. If it's stopping in one turn from brake drag, that's too tight.
Once you have them adjusted up, driving in reverse at 5mph or so and stabbing the brake pedal a few times will keep them adjusted.
Maybe this can help if you are a visual person
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#46
  • Nov 24, 2012
  • #46
I'll be checking it all, it's getting harder to get stuff done, it's dark around 5 and it's about 20* outside now. my main goal is to get the other cable swapped ( it seems to work fine but i like to have it all even.) as well as the brake hardware. The main thing is this, there is a light at the end of this tunnel.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#47
  • Nov 24, 2012
  • #47
I think my final question is this. As I'm testing the brakes before I drive it, with the rear end in the air, should the brakes be enough to kill the engine ? I know the power of front and rear can, not sure here.
tca7291
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 24, 2012
#48
  • Nov 24, 2012
  • #48
Manual transmission, in first gear, idling? Yes.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#49
  • Nov 24, 2012
  • #49
I'm close then
tca7291
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 24, 2012
#50
  • Nov 24, 2012
  • #50
Is it causing the engine to stall at idle when you press hard on the brake petal? Or, are you still talking about just using the e-brake? Stomping on the petal hard with the engine just idling in gear should cause it to stall, but just the e-brake alone generally won't.
tca7291
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 24, 2012
#51
  • Nov 24, 2012
  • #51
I also have to add that it will make a difference depending on your rear end gearing, and how healthy the engine is running, and also general idle speed.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#52
  • Nov 24, 2012
  • #52
It has 410:1 gears.
I'm talking about the regular brakes.
So far using the regular brakes I've been able to get the idle to drop but that's about it. But I've only started adjusting them.
tca7291
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 24, 2012
#53
  • Nov 24, 2012
  • #53
With 410's, I almost would think that you wouldn't be able to stall the engine, I was more referring to the stock 273's. Remember, with the 410's you have almost twice the amount of torque going to the axles then you would have stock. IMHO, I think you are good! I'm glad you got it all working and everything back together alright! I would say mission accomplished, if it were me!
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#54
  • Nov 24, 2012
  • #54
I've not tested it on the road but I can't turn them by hand when pressed and the second I oress in the clutch it stops. It's cold so it'll wait till tomorrow for a road test.
tca7291
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Nov 24, 2012
#55
  • Nov 24, 2012
  • #55
I know it is bad advice, and kinda dangerous, but the best road test for back brakes in a fox body is to get the car going 35-40 mph and brake really hard with the clutch in, and if the rear locks up, your good. Probably shouldn't follow my advice for safety sake...
91TwighlightGT
20+ Year Stangneter
Sep 8, 2002
1,190
375
124
Missouri
Nov 24, 2012
#56
  • Nov 24, 2012
  • #56
Just do be clear, did you replace the cables on both sides? It is my experience that if one is bad, the other is either also bad or on it's way out.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 24, 2012
#57
  • Nov 24, 2012
  • #57
I replaced one, I'll be doing the other soon. Ran out of light/time, but it's for sure getting done, already got the part.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 25, 2012
#58
  • Nov 25, 2012
  • #58
Ok, did the drive test. It stops fine. I did lots of driveway test, then found a slow road and got them to lock up a few times. The parking brake won't lock them up, but it does let me park on a incline. I'll be replacing everything on the passenger side this week some time. Thanks for all the help! Stangnet ftw!
Reactions: Cory Berg
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Nov 25, 2012
#59
  • Nov 25, 2012
  • #59
wait, you did a one sided brake job? You have new shoes and hardware on one side all adjusted up and the other side old shoes, hardware and not adjusted? That's not advisable.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 25, 2012
#60
  • Nov 25, 2012
  • #60
I've said multiple times I'm doing the other side.. Minus test drives, it's not being driven.
The other side will be done this week, I was fixing the side with the issue first, the passenger side is next. I'm aware that you gotta do both sides.
  • 3
  • 4
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
D
Resolved 1985 GT brake pedal problems
  • DienstXIV
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
DienstXIV
D
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
