  • Mustang Sound & Shine All
fixing a bad install
  • Thread starter Thread starter o0akoni0o
  • Start date Start date Dec 25, 2004
O
o0akoni0o
175
Fremont, CA
Dec 25, 2004
  • Dec 25, 2004
well my friends bro got me a good deal on a pioneer hu for my mach 460. problem is i think he didn't do the install right and he's out of town for the next couple weeks. anyways the system has seemed to have loss all of its bass and it seems very high pitched. a cousin of mine told me that he should've used some kind of adapter. anyways, what do i need to fix this? and will this be something i can do by myself considering i have never worked on a car stereo before?
Z
zcs626
260
dallas
Dec 27, 2004
  • Dec 27, 2004
he probably forgot to hook up the amp turn on wire for the subs, maybe?
saxman9801
241
Boise Idaho
Dec 28, 2004
  • Dec 28, 2004
You need to find out if he used a harness or what he used to hook it up and depending on how handy you are you should be able to get it hooked up, get it apart and see what he used to hook it up and take pics if you can and that will be a good starting place. Good luck Dan
O
o0akoni0o
175
Fremont, CA
Dec 29, 2004
  • Dec 29, 2004
hey guys, i took a look at it and i saw several things that were not connected. first were two cable outputs (red and white), like the kind you see on a/v connectors and i think these came from the pioneer hu. and then there were several plugs that look like they came from the factory amp beneath the factory cd player. one was a small plag connector labeled amp. and the other two were the same size but one red and the other was black, they were bigger then the amp connector and had a label ford......hope this helps. sorry i dont have a digital camera avaliable to me at this moment. and my lack of stereo knowledge leads me to describe it like that.
saxman9801
241
Boise Idaho
Dec 29, 2004
  • Dec 29, 2004
OK from the back of the pioneer deck there should be a black plug that comes out of it into a harness, follow this harness into the car, it should attach to another harness in the car, one is a small square plug that looks metallic and black, the wires are grey and the other harness is a rectangular plug that should be grey and black on the plug. Both these plugs are in the opening for the deck not the cd player, try and find those and let me know what u find. Dan
O
o0akoni0o
175
Fremont, CA
Dec 30, 2004
  • Dec 30, 2004
i took another look at it and the only harness i could find coming out of the deck had a bunch of white wires. the plugs i saw earlier that were not connected were black and metallic, and the other was red and black, and one more labeled amp. oh, and i saw two wires, one blue and one black hanging out of the deck not connected to anything. one said grounding and the other said power antenna. i bet i could take a better look if i removed the hu but i'm such a noob i don't even know how to do that. i knew how to take off the factory ones, but i'm not quite sure how to remove the pioneer deck.
O
o0akoni0o
175
Fremont, CA
Dec 31, 2004
  • Dec 31, 2004
any ideas?
saxman9801
241
Boise Idaho
Jan 2, 2005
  • Jan 2, 2005
That blue wire is the system turn on if it is coming from the deck, you need it to tell the mach system to turn on, and the black wire is ground again needed for correct operation of the deck, you really need to get the deck out and see what happened back there and get some pics, you need the two flat keys that go down the side of the pioneer deck and they will release it, get it out and do like i said and trace from the deck back, and see what harnesses were used and which were not. At this point if you are not comfortable i would just spend the 50 bucks and have a shop re do it but it is up to you if you tell me what you find behind the deck i am more that willing to help you try and figure it out, pics would really help. Good luck Dan
saxman9801
241
Boise Idaho
Jan 2, 2005
  • Jan 2, 2005
Tommorow if it is not snowing i will try and take some pics of the install of a mach 460 in a 96 vert to show you what harnesses you are looking for. Dan
O
o0akoni0o
175
Fremont, CA
Jan 2, 2005
#10
  • Jan 2, 2005
  • #10
thanks man i really appreciate it.
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Tuesday at 9:46 AM
josep4
J
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
