Flexplate Woes
GrandeStang73
93
VA
I have a 351C with a C-4 pan fill tranny with a 11-7/16" boltpattern, I can find torque converters but i cant find a flexplate that will fit inside the tranny housing also. If anyone has info. that'd be great. :SNSign:
Do you have a convertor? If not where are you getting the bolt center? what spline input shaft does you C4 have? I am running a C4 with 26 spline input shaft and I have a 157 tooth flywheel and you buy the convertor to match the flywheel. This combo will fit in all ford bellhousings...the cleveland/windsor bellhousings generally except up to a 164 tooth but I have seen some light truck C4 that had big block bellhousings that took a 184 tooth...not common though...
