Flowtech Stinger Exhaust Question
93gtmustang
524
43
49
Has anyone on here used the Flowtech Stinger Exhaust System?
Link Holley Performance Products Stinger Exhaust System*42601FLT
It says 50 state legal.
I like the idea of of the bypass cap so you can have an open exhaust when you go to the track.
If you view the instruction, it shows the exhaust going back over the rear axle.
Is it legal to run an exhaust before the rear axle with turndowns like the picture shows?
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 4.30 Gears / Detroit Locker / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump
