  • 1994 - 1995 Specific Tech
fluidine radiator doesnt fit
  • Thread starter Thread starter stang723
  • Start date Start date Feb 9, 2004
stang723
163
houston, texas
Feb 9, 2004
  • Feb 9, 2004
We'll just spent close to 400 on a fluidine aluminum radiator, and it seems to be alot thicker than the one before, and it doesnt fit once the electric fan is hooked up to it, whats the problem...it supposed to fit without modification right? The fan shroud is rubbiing against the water pump..argh
mytight95
2,605
Dothan,Al
Feb 9, 2004
  • Feb 9, 2004
mine fit check how you mounted it
jason
95BLBLVert
486
Lake Wylie, SC
Feb 9, 2004
  • Feb 9, 2004
I don't have an answer but I was thinking the same thing. Since the unit is thicker, I thought the fan would touch the water pump. Guess I was right. Fluidyne does say it's supposed to fit. If you call their tech line, let us know what they say.
stang723
163
houston, texas
Feb 9, 2004
  • Feb 9, 2004
mytight95' did you install it any different than the stock one was installed?, I will let u know
fastfive0
"Your girl likes my stang better"
1,462
Wilkes-Barre,Pa
Feb 9, 2004
  • Feb 9, 2004
Check your install again. Mine was a DIRECT drop in. I swapped my radiator faster then I can change my spark plugs.
Killer95Stang
256
Covina, CA
Feb 10, 2004
  • Feb 10, 2004
Mine fit perfect... it might not be seated all the way down, and the loom right up front above the radiator is keeping it pushed forward. If you need extra clearance to seat the radiator, just loosen the two bolts that hold the ABS control module on the frame, and it will slide into place nicely. I've personally installed three different Fluidynes (in my car), and they all had plenty of clearance from the water pump...
stang723
163
houston, texas
Feb 10, 2004
  • Feb 10, 2004
well do you guys have electic fans with the motor in the center?, Because it is the motor on the fan that is up against the water pump., so i ordered a bracket to relocate it.
R
rudeone707
1,829
Fairfield, Ca
Feb 10, 2004
  • Feb 10, 2004
i have the summit aluminum radiator and my fan clearance is like 1/2 an inch.
stang723 can you take some pics of what its looking like?
stang723
163
houston, texas
Feb 10, 2004
  • Feb 10, 2004
nah, i dont have a digital camera or anything to put pics up, but do your electric fans have the motor in the center of the fan, because thats the part that sticks out.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Feb 10, 2004
#10
  • Feb 10, 2004
  • #10
yea all 94-95's are gonna have the motor in the middle if they still have the stock fan.
S/CBlack95GT
2,018
Tampa Palms, FL
Feb 10, 2004
#11
  • Feb 10, 2004
  • #11
Mine fit even with my HUGE blower pulley, although there is only about a 1/4" gap b/t the fan and the blower pulley. The motor shouldnt be anywhere near the water pump though?
mustangt562
226
Long Beach
Feb 10, 2004
#12
  • Feb 10, 2004
  • #12
humm
no problem dropping in mine. it fit great with the stock fan. I was suprised cause its significant thickness. Hell usually noting bolts onto my car without something going wrong, but not the case with the fluidyne.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
For Sale 91 Mustang LX 5.0 Coupe 6-speed
  • fastang67
  • Nov 30, 2023
4K
Fox Body Mustangs For Sale (1979-93) Jul 17, 2024
FastDriver
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Aluminum radiator with aluminum shroud install question
  • Woody3882
  • Jul 19, 2021
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 22, 2021
MARKDTN
M
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
