forged rebuild kit?
  • Thread starter Thread starter laserstang21
  • Start date Start date Jul 14, 2008
laserstang21
79
luling, La
Jul 14, 2008
  • Jul 14, 2008
ok as some of you know im gonna put a kb 2.1 on my car and i wanna rebuild the motor so when i push the limits my motor is ready.i will also be getting a t56 trans, and rebuilding the rear end with 31 spline strange axles. so my question is where to find the forged rebuild kit?
laserstang21
79
luling, La
Jul 15, 2008
  • Jul 15, 2008
seeing as noone answered to my thread i guess there is no forged rebuild kit for my gt, right? if there isnt can some one help me out? i want to no everything that i need to build a built bottom end. and also where can i find everything in one plance at a good price. no stroker kits.
lvmustanggt
721
Las Vegas
Jul 16, 2008
  • Jul 16, 2008
sorry that no one is helping you, and sorry that I don't know where to get one
Try MMR
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 16, 2008
  • Jul 16, 2008
Patience grasshopper.....you waited all of 18-minutes between posts after starting this thread after 11 o’clock at night and you assume the answers are going to come pouring in right away? Some people on this site work in the wee hours of the morning, you know?
As for forged internal components, I got mine through Modular Performance.com. I went with Diamond pistons and Manley H-Beam rods which is more than stout enough for anything a 2.1L could possibly throw at it. Don’t bother spending another $500 on a steel crank either, just have the stocker rebalanced. The stock nodular iron unit is good for well over 600hp if kept within the stock RPM limits.
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
Jul 16, 2008
  • Jul 16, 2008
the OP's question was actually a really good one! I've been wondering this myself.
I have a few questions.
I thought a forged crank would be way better than a cast crank, as if you ever wanted to really push the boost up so it could handle it?
also when you buy a forged kit, is there anything really special that needs to be done or is it something that a Ford Master Certified Mechanic could do?
what exactly does forging a block consist of? and could I use my stock block and how much hp is the stock block good for?
i was thinking of buying a forged shortblock from Modular Powerhouse, but they want $3495 for an 800 hp rated MPH Shortblock....i can't see spending that kind of dough on just a shortblock, maybe a longblock, but not a shortblock.
im wanting to push about 600 rwhp, but you know how that goes, eventually it would turn into 700 or 800...especially knowing the way I am.
also I'm putting in a KB 2.6 or a KB 2.8, just haven't decided which yet.
laserstang21
79
luling, La
Jul 16, 2008
  • Jul 16, 2008
im in the sameboat mixed breed. the 2.1 is just 2 get me satrted with boost. when im doon this car will see just weekends and get to the track on a trailer and the car will have a cage in it. i plan on puting a 2.6 kit on by the end and would like to make 700- 800 rwhp.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 16, 2008
  • Jul 16, 2008
Let me put it this way, I've never seen or heard of a stock crank shaft failing. The stock block is good for probably just south of 1,000hp and as stated before the stock crank is rated for well over 600hp...but many have pushed them far beyond that. It's RPM that will kill your stock crank shaft at these levels, not necessarily horsepower.
The kits install the same as they do in an OHV engine. Tolerances in most cases are a little closer, but not much. I really don't know what to tell you other than if you decide to assemble it yourself, get a "good" shop manual (not Hayes or Chiltons) that contains all the proper specs and go to town.
And mixedbreed02gt, be prepared to spend some money if you dare to even venture close to those power levels. Most proper build packages will cost you in the $10-$12 range with all the supporting mods and hardware and can venture up to as high as $20k....so start saving your pennies.
To be honest, if you guys know that you'll be shooting for those power levels eventually, skip the 2.1L and go for the gusto right away. The 2.6L can always be underpulleyed to work with your stock engine until funds permit. But having to upgrade twice is not only expensive, but a big PITA to tear everything off again and start from scratch.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
