Ball Joints repalced
I just pressed the lower ball joints out of my 91 Stang on both sides with no problem. NAPA sells replacement ball joints. Of course they would rather sell you the whole lower control arm!! If the arms are in good shape along with the bushings, just change the ball joints.I just replaced the steering rack, outer tie-rod ends, and lower ball joints. Car had 130,000 on original front end parts. Made a big difference in the ride. You just need to get a press to press them out and press them in. AutoZone may have one you can rent. I borrowed one from a friend and changed them right in my driveway.. Not a bad job, took about 1 hour to change the ball joints out!!
P.S YOU WILL NEED A WIDE BALL JOINT FORK ALSO, TO RELEASE THE BALL JOINT FROM THE SPINDLE. THE AUTO PARTS STORE WILL KNOW WHAT YOU'RE TALKING ABOUT
Good Luck,
BLK3dgt
