Fox Box
  • Thread starter Thread starter SAKKI
  • Start date Start date Sep 28, 2005
SAKKI
9
  • Sep 28, 2005
HELLO ALL
i was wondering if anyone has installed a chicane fox box cold air kit for their car, iwas looking into getting a fender kit simply because my car has the conical filter just sitting in the engine bay and it probably isnt good to be sucking in all that hot air and the fox box looks the best so far...i still have to measure my throttle bdy to check the size but it is definately bigger then stock,,but the mass air sensor is stock should that be swapped out for something bigger since the tbody is?? thanks in advance..
Matty469
77
Hawaii
Sep 28, 2005
  • Sep 28, 2005
Not really. Your Mass Air unit is changed to recalibrate for larger fuel injectors. Not throttle body changes.
SAKKI
9
  • Sep 28, 2005
actually the injectors are changed need to figure out what size they are i will take a look because there are little tags still on them,,,sorry i sound oblivious to my own car but i purchased it from someone who put all this togethr and then sold it for a bike so they did not test and tune it after all the mods...so i am picking it apart little byt little with help from people here..
Matty469
77
Hawaii
Sep 28, 2005
  • Sep 28, 2005
If they are 24# they should be blue. And it depends on who makes your mass air unit as to what size it is and what for. For instance my C&L MAF is 76 mm and calibrated for 24# injectors.Granatelli makes a 75mm MAF for 24# inj, and the cobra MAF is a 70mm for the 24# inj.
SAKKI
9
  • Sep 28, 2005
im lost with that,,,but i will check tomorrow and get back to this post with what color and hopefully size...from the looks the tbody and injectors were changed but not the mass air sensor??makes no sense but i will check it out..
SAKKI
9
  • Sep 29, 2005
well i checked the injectors and they look yellow, the throttle body i need to remove and measure when i take that off can i reuse the gasket? the tbody is attached to what looks like a chrome spacer then the breadbox intake..at what point would i change the injectors just when a larger mass air is installed? and what will that do for me?
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
