Fox brake gurus inside please.
  • Thread starter Thread starter squeak93
  • Start date Start date Jun 6, 2008
squeak93
2,352
417
164
Joplin, Missouri
Jun 6, 2008
  • Jun 6, 2008
So long story short. MY brakes suck. Right now the pedal is very hard. all new hardware on all conrners (pads rotors and turned drums with new rear hardware) Also new master cylinder. We bleed everything and they worked ok with the old 302 in it. But now with the 351 it has a lot less vacumn to deal with so that my be most of my stopping problem. What do u guys think?
Now time for the rear problems. When I hit my high rpms at wot....my parking brake light comes on and my brakes engage in the rear brakes. I can feel them grab the same time the light comes on. They are assembled with all new hardware by the book. No clue what is causing this. This is my last hurdle before I can make some passes so i want to get fixed asap. Anyone have a clue?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 6, 2008
  • Jun 6, 2008
Loss of vacuum. Either install a vacuum resevior or look into installing a larger volume booster like '93 Cobra or SN95. I'd go the canister route though either way
Parking brake light is also the low fluid sensor on the MC reseviour. Commonly, when you go WOT, the fluid sloshes around and uncovers the light and trips it. Adding more fluid will fix the prob.
Those are the only two triggers for the light...the low fluid sensor or the e-brake handle. There is no other tie in into the brake system.
The brakes can only engage if you press the pedal since it needs mechanical force to activate the hydraulic system. I don't know what to say about feeling the brakes grab. Are you sure? Or is the car hitting a flat spot in the RPM's??
93 LX
3,081
Norwalk, CA.
Jun 6, 2008
  • Jun 6, 2008
check how tight the ebrake is adjusted. If it s tight and the rear wraps a bit it could be enough to apply the brakes. The light is most likely the fluid level sensor.
squeak93
2,352
417
164
Joplin, Missouri
Jun 9, 2008
  • Jun 9, 2008
It was both a and b. The fluid was sloshing around, filled higher, no more light and we were playing with the tune so it just so happened to get a nasty miss at the same time as everything else. so it through us off by accident. Car is pulling pretty good just need to get either a wideband or a good dyno tune.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
