- Oct 21, 2006
- 515
- 43
- 49
Where can I purchase books for Fox Mustangs that have good detailed instructions on how to perform all sorts of different projects, repair and trouble shooting.
Which are the best books out there?
I'm lookin to change my rear axle seal and maybe do a gear swap this winter, but I need some detailed instructions.
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Thanks
