Foxbody Cobra Grille Insert
187
I bought one of those cobra grill inserts for my 87 foxbody but after I cut out the hole the over lay dosent set clutch because there is a little nipple that sticks out should I drill a hole in the bumper cover or should I cut it off??? Has any body else has the little nipple on there insert? Or is it just a casting thanks
No nipple on my insert, and having trouble grasping where that pic is showing.
I have a Cervinis grill, but I haven't installed it however. Can't bring myself to cut a good OEM LX bumper and do a mod that cannot be reversed.
My cobra grill hangs on my wall instead.
Reactions: elarm1
If that the case.... Box it in with epoxy (or even gel super glue), cut the nipple off, sand on it a little and press on with pride. :)
If that is the back side of a rivet (what it looks like) then there's a head to that rivet on the other side.
...and if THAT is true then just drill the whole rivet out AFTER the glue/epoxy.
