Foxbody Tachometer "Jumpy"
KaLiKo Street
73
My 92 that im currently in the middle of doing the 5.0 swap with, has always had a problem with the tachometer either not working or being jumpy. Anyone know why? My old 85mph gauges did it and now a whole newer set of 140mph gauges do the same thing...It must be a wiring problem somewhere. Heres two vids of what I mean...
This one is where it just stopped working...
And this one is where its kinda jumpy and wants to work...
Look closely at the wiring coming off the TFI module. One of the wires is dark green/yellow and is labeled IDM. It has a 22k K ohm resistor and the wire connects to pin 4 on the computer. The same wire feeds signal to the tach. If the wire is loose, damaged or the resistor is damaged, you could have tach problems.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
