Foxbody Tranny In A 94 Cobra?
cobra360
Havelock, NC
The tko-600 in my 94 cobra has broken. I am trying to sell the car and want to throw a cheap t5 in it. The only manual transmission I can find in nearby salvage yards comes from an 87 gt. To go back to the t-5 I need a new bellhousing, d/s yoke, crossmember, and 28 spline clutch. Will any of this bolt up if I rip it off of the 87? Thanks!
A TKO-600 is set up for a Foxbody in the first place, so it should actually be easier to put Fox T5 in your car, than an SN T5. I would assume that since you have a TKO-600, then your car has already had all the conversions such as the driveshaft spacer and a Fox clutch fork. Everything should bolt right up. Just make sure you use the Foxbody bellhousing and you should be fine.
Kurt
