So i figured since I was tuning the newest combo i would share the experience with all of you, This will be my first attempt at tuning a MAF setup from start to finish.
The car is already running and idling in closed loop with the ign timing locked out in TS at 15*, I must still verify timing with a light.
The combo is as follows.
-306CID SBF with Stock crank and rods, DSS street forged pistons, total seal TS-1 gapless rings.
-GT 40 heads with port work and 2.02, 1.6 valves
-custom intake manifold with adapter for a M112 blower pulled off a wrecked XKR Jaguar
-I had to make the adapter and the inlet plenum for the blower
-BBK fuel rails with 47lbhr FORD racing injectors
- Ignition system is handled as wasted spark using a custom trigger wheel setup and coil packs from a early 2v 4.6
This build utilizes a heavily modified DIYPNP with semi sequential injection and ignition mods... I also have a JBperf. Tinyixo handling all the IO for the fans/wmeth/pwm outputs ect since the microsquirt card was fully taxed by the mods. the tiny io and the microsquirt talk over canbus.
I will attach a copy of the tune i am working with along with the first datalog of the car running on MAF.
