Front end noise
  • Thread starter Thread starter stang1986GT
  • Start date Start date Sep 10, 2007
stang1986GT
143
Charleston, WV area
Sep 10, 2007
  • Sep 10, 2007
I have an 86 GT, and it's always had this noise at the front end. When I go across railroad tracks or up my gravel driveway, it seems like something is loose in the suspension travel..just can hear something banging around slightly. Could this be the inner tie rod ends? What else should I check while under the car? I'm more used to older Mustangs where you just check the ball joints and be done with it...anything on the rack I should be looking at?
Thanks.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 10, 2007
  • Sep 10, 2007
i say check the ball joints first. and tie rod ends shouldnt rattle at all. if they where that worn out you could feel it when you turn and your car would pull from side to side.
stang1986GT
143
Charleston, WV area
Sep 10, 2007
  • Sep 10, 2007
That's what I thought on the tie rod ends...steers tight. Thanks a lot!
MahFiVeOh
531
9
49
Ontario, Canada
Sep 10, 2007
  • Sep 10, 2007
I had a similar noise with my car a while back.It ended up being the front caliper bolts (sliders) The rubber bushing was deteriorated and caused a clunking noise when ever i went over a rough road or bump.Maybe thats your problem.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Sep 10, 2007
  • Sep 10, 2007
take your front brakes apart and clean and lube everything....and replace parts if they are worn...Mine make a rattle noise over some bumps. Been meaning to do that but never found the time.
C
cjnecessary
70
richmond,in
Sep 11, 2007
  • Sep 11, 2007
How about the sway bar links (stabilzer links)?
stang1986GT
143
Charleston, WV area
Sep 11, 2007
  • Sep 11, 2007
The sway bar links are new. I now recall thinking that the sway bar bushings I put on were a little too large...I totally forgot about that (I sold this car once and then got it back after about a year so I've forgotten everything I've done to it)...I need to check that again. It's a shame that there are 264 different sway bar sizes...lol.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Sep 11, 2007
  • Sep 11, 2007
yes they could rattle aroud in a too big of a bushing lol
stang1986GT
143
Charleston, WV area
Sep 12, 2007
  • Sep 12, 2007
Yep...haha. I just need to take a weekend and crawl under the car and check everything really well. I'm sure I'll find about 10 things to be fixed. Not bad though...it's a really nice little daily driver and at least I don't have a car payment.
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Strut rattle
  • JD1964
  • Apr 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
manicmechanic007
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
