Front end "thump"
  • Thread starter Thread starter BlownStangGT
  • Start date Start date Apr 2, 2005
BlownStangGT
REPEAT
3,860
Lancaster, PA
Apr 2, 2005
  • Apr 2, 2005
well..when I go around a corner while slowing down and I turn, I hear a thump in the front. I think I have narrowed it down to eitehr the sway bar mounts or the end links...would these be the right cause? I have replaced the one sway bar mount cause it broke, so I kinda checked them with the hood open and they looked ok, havnt checked the end links yet casue its raining out
T
ty-rone
77
  • Apr 2, 2005
To check the sway bar, open the hood and bounce the front end. If you hear a binding sound that would most likley be a sway bar. If you have a friend who will help it makes it a lot easier because one of you can listen for the sound.
I think that it is an outter tie rod end. Every car which I have changed tie rod ends has suffered from the same noise. I think that if it were the sway bar bushings, you would get a binding sound and not a clunk.
HISSIN50
34
129
Apr 2, 2005
  • Apr 2, 2005
dont forget ball joints.
good luck.
Rick 91GT
Mustang Master
95
99
PA
Apr 2, 2005
  • Apr 2, 2005
I agree check the ball joints, jack the front end up and put a large pry bar under the tire and pull up see if the tire moves, also see if it moves in/out.
T
ty-rone
77
  • Apr 2, 2005
I thought I said ball joints too:| Well ya, balljoint and tie rods most common.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Apr 2, 2005
  • Apr 2, 2005
Aight, Ill check it, I have some ideas of what it might be and I hope its not ball joints for sure...Thanks for the help
HISSIN50
34
129
Apr 2, 2005
  • Apr 2, 2005
why? Ball joints are no biggie to swap. there is lots of other stuff i would rather not swap. LOL.
T
ty-rone
77
  • Apr 3, 2005
ball joints are a joy compared to the inner suspension parts:|
BlownStangGT
REPEAT
3,860
Lancaster, PA
Apr 4, 2005
  • Apr 4, 2005
Crwaled under the car, looked at it and seen the end links were broke, so I went ahead and got some energy suspension ones, put them on and all is good, rides better I think also
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
Strut rattle
  • JD1964
  • Apr 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
manicmechanic007
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
