SN95 Front passenger window regulator adjustment (window doesn't roll up "evenly")
  • Thread starter Thread starter acpowell
  • Start date Start date Aug 20, 2018
acpowell
23
Michigan
Aug 20, 2018
  • Aug 20, 2018
I have/had some issues with the motor on my passenger side front window (will need to replace drivers side soon also). I removed the motor and regulator, did the repair on the motor got it all back in but now it seems like the window doesn't come up evenly. It will roll up about half way and get stuck, if you pull the window back a little it will then roll up some more. It looks like the back of the window is moving up before the front of the window is. I greased the regulator when it was all put back together. That being said I am sure it needs to be adjusted some how but I am not sure how to do that.
The repair I did was for the motor bushings and it was only until I buy a new motor/regulator assembly so I will need to remove it again and I don't want to mess the new one up either. Any advice/help would be appreciated.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Aug 20, 2018
  • Aug 20, 2018
So the stops are incorrect or just the alignment itself? You can grease up that track, once the speaker is amazing how much room is in there.
I would do the entire install again and see if it still does it. Remove the motor and start over. I had to do mine a few times.
acpowell
23
Michigan
Aug 20, 2018
  • Aug 20, 2018
I never thought to remove the speaker. I riveted mine back in. So that will be a pain. Did you use bolts? What size/kind if so?
Reactions: Essn95
acpowell
23
Michigan
Sep 12, 2018
  • Sep 12, 2018
So fun recap on this, I just replaced the window regulators and motors in the front and the gear plugs in the back. Everything rolls up and down now.
Reactions: General karthief
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
