i have a 68 coupe thinking of using a 460 in it i found that www.rrs-online.com has a sturt tower notching kit. but you have to use there front suspension and brakes has anyone used there parts
i want a big notch so i can get a set of 3 inch headers in it and be able to change the plugs with out pulling the engine out.
I missed that in reading the original post. My sewer pipe under the house is 4" pvc; maybe he could use that to save money on steel. Seriously, 3" is beyond rediculous and has entered into the "ludicrous" zone.i want a big notch so i can get a set of 3 inch headers in it [/url]
even top fuel dragsters dont use 3" header pipes, and they make 7000hp! a 2" header pipe is about as big as you want to go.i want a big notch so i can get a set of 3 inch headers in it and be able to change the plugs with out pulling the engine out. the rrs kit uses a strut mounted to the spindle so no upper control arm heres there gallery on it http://www.rrs-online.com/assets/galleries/notchfit/index.htm
Big blocks were optional in '67 so its doable. The exaust ports point down vs out to the side like 302s or 351s. Now if you're doing headers too maybe you want to notch something but you don't have to since the 390 was optional.
Oh? i didn't know there were big blocks after the FE.The FE big blocks not the 385 Big Blocks were available in 67. However, you do not have to notch the towers to fit a 429/460 with headers, it will just be extremely tight in there. It is almost impossible to change plugs on my with just the stock exhaust manifolds.
not really 3 inchs but close the reason im thinking of the rrs parts is its less work then a mustang 2 clip and doesnt move the engine up and foward 4k isnt nothing when i done spent almost that on a block
