front suspension torque specs
67fstbck
28
michigan
anybody have torque specs for the front end of a 67 mustang I need the following.
Strut rods (the big nut and the two smaller bolts for the lower arm) upper and lower control arm mounting bolts, upper and lower ball joints also are there suppose to be washers on the two bolts from the strut rod to lower control arm and finally has any one had trouble lining up the two holes in the lower arm with the strut rod bolts the drivers side went together fine but the passengers side looks like I will need to do a lot of prying.
Thanks for the help
Chris
