  • SN95 4.6L Mustang Tech
Frpp Gear Install Kit?
  • Thread starter Thread starter swl987
  • Start date Start date Apr 28, 2005
swl987
200
Cleveland,Oh
Apr 28, 2005
  • Apr 28, 2005
this mechanic told me i need to buy a install kit for a hundred bucks when i install frpp gears. i told him it comes with shims and he said that he also needs the seals etc. my car only has 6000 miles on it. what do you guys think? he said it will make it alot easier for him. he also said it would take him 6 or seven hours to do it costing me 600-700 bucks total. sounds like horse**** to me.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Apr 28, 2005
  • Apr 28, 2005
If they know that they're doing...4.5 hours tops. Shouldn't take any longer than that. And for your seals, I would just go ahead and replace them...why not? If you don't, that 6000 miles is going to come back and bite you in the arse. JMO
hotmustang331
2,967
Bastrop,TX
Apr 28, 2005
  • Apr 28, 2005
I had around 19K on my rearend when I put in 3.73s (now 19.7K)...didnt replace ANYTHING, dont need the shims either...just keep the stock shim behind the bearing on the pinion. No noise either and just as tight as stock. All you need to do is swap the spacers that line up the carrier and keep it tight...put the left one on the right and visa versa..its very easy to install gears (besides beating the pinion out of the housing..takes some work, and need a 2LB+ hammer...also remember to screw the nut back on the pinion before you beat on it).You should do it yourself...otherwise it shouldnt cost no more than $200-300.
ADRENLN
2,342
NJ
Apr 29, 2005
  • Apr 29, 2005
im doing the same swap may sometime, and id say replace everything. my car only has 9200 miles also. im not 100% sure yet on what exact kit to get, but you will want one that will replace the bearings.
the price he quated you is way too high.
ponygirl74
69
Chattanooga, TN
Apr 29, 2005
  • Apr 29, 2005
Ratech
I would go ahead and get the kit because it may save you in the long run. I got the install kit from Ratech. I'd shop around for the gear swap though. I'm paying $225 to get mine installed Monday, so if he said $600+ that is a bunch of bs!
crazynorwegian
20+ Year Stangneter
Nov 6, 2003
267
azusa, ca
Apr 29, 2005
  • Apr 29, 2005
the shop I got mine done at installed my installation kit, gears, and replaced all my clutch packs in my trac-loc in about 2 1/2 hours. it came to a total of $290 for labor, and oil. I would call around and get some quotes from other shops. I've seen a lot of mechanics screw people on gear installs. If you want to buy a installation kit you can buy one that just includes the seals and bolts. so you wont have to pay for new bearings. gefracing.com sells one for 38.50 here's a link to it
http://www.gefracing.com/Merchant2/...de=G&Product_Code=M4210A&Category_Code=46REAR
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
