Fuel float question
  • Thread starter Thread starter jcgafford
  • Start date Start date Jan 27, 2012
jcgafford
1,114
95
104
Adrian, MI
Jan 27, 2012
  • Jan 27, 2012
So I am replacing the fuel tank on my 92 5.0 and pulled the old fuel float out, cleaned it up and ran into a question. The float itself, the little black foam on the end of the swing arm, has a couple wear spots where the actual steel rod that it resides on has cut grooves into it. To me it looks like there should be something more than just the bent wire holding it on and perhaps a washer or something to protect the edges on it from the wire. Perhaps I am overthinking/overengineering it? Also should the actual float be able to swivel around freely? Seems like it should be stationary on the swing arm wire . First time I have ever pulled one so I am clueless. Help?
txstang84
1,639
42
69
Tuscola, tx
Jan 27, 2012
  • Jan 27, 2012
If it still floats and stays in the holder, I'd say you're good...
jcgafford
1,114
95
104
Adrian, MI
Jan 27, 2012
  • Jan 27, 2012
just worried i will get it all together and the wire will catch in the grooves.... half the time guage will work, and then it won't. know what i'm sayin?
txstang84
1,639
42
69
Tuscola, tx
Jan 27, 2012
  • Jan 27, 2012
ah ok...well if you already have known issues with the assembly, just replace it and be done.
jcgafford
1,114
95
104
Adrian, MI
Jan 28, 2012
  • Jan 28, 2012
assembly is in good shape, just the actual float. hate to spend 90 bucks on something for a simple float that needs replaced. wonder if the actual float can be interchanged with another one?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 28, 2012
  • Jan 28, 2012
You're just way overthinking things.
Here's a brand new one. It ain't very complicated.
jcgafford
1,114
95
104
Adrian, MI
Jan 28, 2012
  • Jan 28, 2012
right, but that whole dealy is like 90 bucks. be nice just to replace the black float at the end for 5 bucks instead.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 28, 2012
  • Jan 28, 2012
What I'm saying is that the float is a solid block. Any wear on it isn't of a consequence at all.
jcgafford
1,114
95
104
Adrian, MI
Jan 28, 2012
  • Jan 28, 2012
gotcha
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
J
Fuel pump question
  • jay99914
  • Feb 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 5, 2025
89ripper
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
H
Fuel gauge racking my brain..
  • hoggle33157
  • Sep 7, 2023
1996 - 2004 SN95 Mustang -General/Talk- Sep 8, 2023
weendoggy
Fuel pressure not holding
  • Creomod
  • May 6, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2023
dcm0123
D
