  • 2005 - 2014 Specific V6 Tech
Electrical Fuel level Low, DTE ODO data error
  • Thread starter Thread starter TeddyBxar
  • Start date Start date Jun 30, 2025
T
TeddyBxar
MI
Jun 30, 2025
  • Jun 30, 2025
I have a 2006 4.0L automatic base mustang. It’s stock. It popped this “DTE ODO data error” on my dash. My odometer is no longer reading, but my RPM’s read fine. My “O/D off” is flashing, and my car shifts really hard.
My initial thought was maybe a fuse issue. But I’m scared it might be a bigger issue, please let me know what it could be ! Thanks!
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Jul 2, 2025
  • Jul 2, 2025
Welcome aboard!
You have already done the cardinal forum sin and that is: Come in here with an issue but no list of ECU codes
So... PULL CODES!
- and list them here.
horse sence
8,597
233
Wile Coyote's stunt double
Jul 2, 2025
  • Jul 2, 2025
Turbine speed sensor more than likely ,it's located on top of the transmission and is a pain to get to! If you drop the tranny mount and let the transmission sag it's fairly easy
horse sence
8,597
233
Jul 2, 2025
  • Jul 2, 2025
My 05 did the same thing .
N
Nathan G
Lehigh Valley, PA
Jun 16, 2026
  • Jun 16, 2026
2007 Mustang GT convertible with about 135K miles. Garage kept. Doesn't see rain.
Hello. I have the same issue, and I have been researching and checking, but still have the error.
I was driving on the highway and the car just stalled. I pulled off to the side and it restarted once. About 2 minutes later, it died again while driving and that was the end.
I am getting the dreaded error "fuel level low dte odo data error check charging system", and I seem to have power to everything else. Stereo works, drop top works, power windows, etc., but when I try to start, it does nothing, doesn't click, doesn't crank, nothing. When I turn the key, the odometer comes up with the mileage and then turns to ---------. Then, the above errors show in the display
At this point, I have had the battery checked, and it is fine, i have changed the alternator and cable set going to the battery, checked continuity on the three wire plug that goes from the alternator to the PCM, all good. I have also checked the fuses and relays and they all seem fine. I have also tried to connect a OBD II scanner, and it wont connect.
The weird thing is, I can charge the battery, and it'll start and run for about 15 seconds, and then die and repeat.
Are there ideas? Anyone else have a similar issue?
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
