Fuel line routing 4 cyl to 5.0
SPEED FREAK
1,448
Regina, SK.
K guys I have a project I'm involved with and I can't quite figure out where the stock 5.0 fuel lines come into the engine compartment from the fender... I did a search and went back to early 05 with no luck. I don't have any friends around here with older fox 5.0s anymore so I can't even do the phone a friend. I'm pretty stumped and these lines are slightly bent in several places so just simply trying to line them up isn't working. It looks like it wants to come in beside the a/c dryer canister but I can't remember. Please help!
Are you routing new ones? or do you have a stock 5.0 setup? If your routing new ones you can route them where ever you want.... ha. I just removed mine caues i'm running bigger ones. But as for your question. I'm not sure how much you have run yet so i'll say the whole thing. They go from the tank to the filter(above the axle) and then down the tunnel(mounted to the passenger side of the tunnel with 2 mounting brackets). Then from there they take a turn right towards the passenger front wheel well. Then if you remove your inner fender... They run up the metal behind the inner fender. Then they go along the side of the strut tower, and go behind your brake line and then tuck up under the front rail and go up to the engine which turnes back into hard line and attaches to your block. Hope that helps? lol...
