Fuel Pressure Sensor with Megasquirt
beyondEOD
86
10
18
Indiana
Anyone running an electronic fuel pressure sensor with your megasquirt. I'm looking to add on on my 95. What is your setup?
  • Sponsors(?)
beyondEOD
86
10
18
Indiana
Thanks got this
Blown88GT
1,975
448
124
Palm Beach Gardens, FL
sweet, I actually use the cheap ones from amazon or ebay for most other things but fuel is best to use a good sensor... dont want a fire
I've had 2 of them fail when the engine is up to normal temp for a while. When they cool down, they work again.
Basically, they're good for the first 30 minutes after a cold start.
Blown88GT
1,975
448
124
@Blownwhat do you recommend? Holley sensor?
I can't recommend any of them, but this is what I use.
DemonGT
634
Sparta,WI
Visit site
Is there a benefit to having the oil pressure set up to show in TS? Asking cause i already have a mechanical oil pressure
and water temp gauges installed in the car. Im guessing id have to unhook those gauges in order to get that info into TS?
Blown88GT
1,975
448
124
No benefit. Oil pressure is not an input the fuel injectors can use.
Blown88GT
1,975
448
124
What inputs dose TS use for autotune etc.? Do i need fuel pressure? I just have a gauge on the schrader valve on the
rail.
The same inputs it uses for non-autotune.
Look in TS. Do you see fuel pressure, anywhere?
Variable Inputs
Manifold Air Temp (Air temp sensor)
Engine Coolant Temp (Coolant temp sensor)
Manifold pressure/vacuum (MAP sensor)
Air/Fuel ratio (O2 sensor)
Static Inputs
Engine Displacement
Injector size
Reactions: DemonGT
DemonGT
634
Sparta,WI
Visit site
Variable Inputs
Static Inputs
Engine Displacement
Injector size
Thanks for the info, this helps.
To answer your question, yes..i do see it
Blown88GT
1,975
448
124
Looks like MS3, not MS2. This feature cannot be used on a '95 which has a return type fuel system. Returnless fuel systems have pressure sensors & variable pressure fuel pumps and/or controllable fuel pressure regulators.
Thread starter Similar threads Forum Replies Date
T Fuel Rail Pressure Sensor Id 1996 - 2004 SN95 Mustang -General/Talk- 5
fatdaddylines Help! Gt Cranks But Only Starts Once In Awhile. 1996 - 2004 SN95 Mustang -General/Talk- 4
S Fuel Pressure Sensor- 2003 Modified Svt Cobra SVT Tech Forum 0
BlackArtemis CEL P0190 - Fuel Rail Pressure Sensor Malfunction SN95 4.6L Mustang Tech 5
S Location of Fuel Tank Pressure Sensor on '01 SN95 V6 Mustang Tech 0
4 Fuel Rail Pressure Sensor pigtail - Where? 2005 - 2014 S-197 Mustang -General/Talk- 0
B Fuel pressure sensor SN95 4.6L Mustang Tech 5
B Fuel Rail Pressure Sensor SN95 4.6L Mustang Tech 6
M Need help...fuel tank pressure sensor circuit low SN95 4.6L Mustang Tech 1
T Fuel rail pressure sensor...? SN95 4.6L Mustang Tech 6
0 Blown fuel rail pressure sensor SVT Tech Forum 6
helty Code P0190: Fuel Rail Pressure Sensor Circuit Malfunction SN95 4.6L Mustang Tech 5
goshia Fuel Pressure sensor SN95 4.6L Mustang Tech 0
J Fuel Fuel Pressure and injectors on a 86 Stang with 3.8 TBI Fox 5.0 Mustang Tech 30
J 86 Mustang 3.8 fuel pressure Fox 5.0 Mustang Tech 0
D please help fuel pressure issue 1996 - 2004 SN95 Mustang -General/Talk- 0
B Fuel Fuel pressure Issues / AFR Fox 5.0 Mustang Tech 0
B Fuel pressure issue 95 mustang 5l 1994 - 1995 Specific Tech 8
A Fuel Pressure Problem. Need help. Other Auto Tech 10
D Fuel Starts W/ Fluid. Torque App Shows No Fuel Pressure at Rail. Help Please SN95 4.6L Mustang Tech 10
R Fuel Fuel pressure problems SN95 V6 Mustang Tech 2
C Fuel Pressure Regulator Help Fox 5.0 Mustang Tech 16
Xenogenesis Fuel Both banks lean, fuel pressure is at 30 SN95 V6 Mustang Tech 6
maisonmays22 Fuel Pressure Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Rt jam Fuel Fuel pressure check 1993 Fox 5.0 Mustang Tech 4
B 93 cobra with Vortech supercharger correct fuel pressure 42 PSI?? Digital Self-tuning Forum 2
C Fuel Pressure erratic SN95 4.6L Mustang Tech 11
P P0190 Code 1996 - 2004 SN95 Mustang -General/Talk- 3
D 2000 Mustang V6 cranks, no start, and no fuel pressure (BUT has started intermittently) SN95 V6 Mustang Tech 3
C Fuel Pressure cuts out intermittingly at idle - comes back after 20 minutes SN95 4.6L Mustang Tech 8
EX-SSP Fuel fuel pressure woes... Fox 5.0 Mustang Tech 5
W Engine fuel pressure regulator or fuel pump? Fox 5.0 Mustang Tech 36
91GTstroked Fuel Bad fuel pressure regulator? Fox 5.0 Mustang Tech 16
M Low Fuel Pressure 1989 LX 5.0 Fox 5.0 Mustang Tech 14
MercRS Fuel Correct fuel pressure tool for 86 Fox 5.0 Mustang Tech 5
F New Fuel Pump/ Injectors Now Car Won't Get Fuel Pressure 1996 - 2004 SN95 Mustang -General/Talk- 1
E No fuel pressure 1994 - 1995 Specific Tech 1
3 Engine Adjustable fuel pressure regulator Fox 5.0 Mustang Tech 2
Bultaco51 intermittent starting 2003 mach 1, why? good fuel pressure 1996 - 2004 SN95 Mustang -General/Talk- 11
D 95 GTS - Fuel Pressure bleed down / How quick? 1994 - 1995 Specific Tech 4
S Fuel 1992 351w Swap Fuel Pressure Issue/problems - Please Help! Fox 5.0 Mustang Tech 13
Ultra90GT SOLD Aeromotive 13102 Fuel Pressure Regulator Engine and Power Adder Parts 1
C Help needed, good fuel pump but no pressure to rails 1996 - 2004 SN95 Mustang -General/Talk- 1
T For Sale Liquid Filled Fuel Pressure Gauge - $60 Other Classifieds 0
S Fuel Low fuel pressure under hard acceleration then pops SN95 4.6L Mustang Tech 4
D Fuel Fuel pressure Fox 5.0 Mustang Tech 8
D No fuel pressure 1996 - 2004 SN95 Mustang -General/Talk- 2
Sparky714 MS DIYPNP fuel pressure input Digital Self-tuning Forum 23
FetusLasVegas Fuel 89 GT low fuel pressure Fox 5.0 Mustang Tech 17
N Cranks burn no start no fuel pressure 1996 - 2004 SN95 Mustang -General/Talk- 1
