I just put together a new motor and want to fine tune it a little more, here's a quick run though of what the motor is.
302, Edelbrock Performer heads with 1.6 rollers, E-cam, Trickflow street heat intake, 65mm TB, 75mm MAF, 24lb injectors, 255LPH fuel pump.
I was reading in one of my books that recomended to set the FP around 42-44 PSI with vac line disconnected for 24 pound injectors. Does that seem right or should I set it to the stock 38-39 PSI rating that I was running with 19's?
