  • 1994 - 1995 Specific Tech
fuel pump help...ASAP
  • Thread starter Thread starter VIPERn94Five-0
  • Start date Start date Jul 27, 2005
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 27, 2005
  • Jul 27, 2005
ok yesterday I was driving home....and the car started to studdder....had no power etc....well anyways i had thought possibly that I had run out of gas....so i went up and grabbed some more gas put it in the car etc....now the fuel pump will not prime when turning the key....ive checked the cut off switch in the trunk and what not but that is all kosher...the pump just wont prime....any ideas?..
.....and to make the day even worse....the last time i tried to get the car started, my key broke off in the ignition
SQUEEZE&STROKE
SOUTHERN CA
Jul 27, 2005
  • Jul 27, 2005
Could bthe fuel pump relay, or most likely the fuel pump itself (from the description you gave)
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 27, 2005
  • Jul 27, 2005
well...was looking through the Haynes manual today before work.....apparently the fuel pump has its own fuse??....called my dad and told him to check out the fuses...and he found a blown 20amp fuse...gonna give that a try....fingers crossed lol
V8302stangs
211
San Jose, CA
Jul 27, 2005
  • Jul 27, 2005
I had a similar problem that did turn out to be the fuel pump, I found out it was the fuel pump after using a friend's scanner. The code was a bit confusing, saying something like "bad ground fuel pump relay" but I bought an upgraded fuel pump, installed it and have zero problems.
HISSIN50
34
129
Jul 27, 2005
  • Jul 27, 2005
The FP relay is housed in the CCRM. One can use the self test connector to jump the FP on for diagnostics.
Checking all fuses is the first move, as you know. I thought (vaguely here) that there was an underhood fuse for the FP.
Good luck.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Jul 27, 2005
  • Jul 27, 2005
hissin is correct there is a 20 amp fuse in the enginebay fuse panel
a50sn95
368
Elk Grove, CA
Jul 27, 2005
  • Jul 27, 2005
By "prime", do you mean it just keeps running and running?
If so, then it's probably the fuel pump itself. I had one that would do this.
It would stop pumping fuel, and the car would die. Then I would just let it sit fro 5 or 10 minutes and it would start back up.
Got progressively worse until one day it wouldn't make any fuel pressure.
I would guess this is your problem....
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 28, 2005
  • Jul 28, 2005
by prime i mean it WONT prime at all...as in...turn the key and you can hear it as the pump turns on the first time....right now it makes no noise....had a busy night last night....gonna try the fuses today on my lunch break....hopefully that works....
Anthony
a50sn95
368
Elk Grove, CA
Jul 28, 2005
  • Jul 28, 2005
Sorry, I'm not following.
If you trun the key to on, but don't start the car, and it runs for a few seconds and stops, then it is priming, and your problem is elsewhere. Fuel filter maybe
If it just runs and runs and runs, then it is not priming, and the pump is the issue.
If it does nothing, then it's the pump, or the wiring, or the inertia switch, etc.......
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 28, 2005
#10
  • Jul 28, 2005
  • #10
haha....yes maybe im being unclear...turn the key to on...it does NOTHING....
HISSIN50
34
129
Jul 28, 2005
#11
  • Jul 28, 2005
  • #11
Have you jumped the self test connector to see if the pump comes on? this makes up for a missing ground pulse from the puter, which is what completes the control side of the FP relay circuit and allows the pump to prime and run.
Good luck.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 28, 2005
#12
  • Jul 28, 2005
  • #12
where is the fuse for the fuel pump??....i hate when my dad plays with my car because he looses things like my owners manual....
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 28, 2005
#13
  • Jul 28, 2005
  • #13
Good luck.
no i havnt....how do i do this?
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jul 29, 2005
#14
  • Jul 29, 2005
  • #14
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
