i have a 92 mustang gt which was running fine until one day while driving the car just died. car will crank but not run. i dont hear fuel pump kicking on. after i got car towed home i found that the dark blue 20 gauge fusible line that connects to starter motor relay was burnt out. replaced with correct fusible link wire and when i turn on ignition the fusible link burns up again! awhile back i had a small fire in the engine compartment and i had to replace the tfi connector with a tfi pigtail. once replaced car has been running fine for a month until it died. have any idea whats causing fusible link to burn up? how do you trace down a short or a ground problem with a digital volt meter?
