Future engine?
  • Thread starter Thread starter bynummustang
  • Start date Start date Sep 14, 2005
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Sep 14, 2005
  • Sep 14, 2005
I have a 1990 LX hatch with a 5.0 and a 5-speed: the clock reads just over 150XXX miles. I'm wonder what everyone thinks, and what I should or shouldn't do.
I plan on boring my stock block to 306 CI, putting either GT-40 or Twisted Wedge heads, a decent cam, and put a 1.7 L Kenny Bell blower with a flowzilla kit, stronger clutch, flywheel, bigger injectors, fuel pump ect.
Other than the lifters, rockers, pushrods, valve springs, and what not, are there any major or big parts that I need to get to make that setup work well. I plan on having it for 'almost' daily driver. Split the week or so with my stock '98 civic.
What do yall think that power and times might be with that?
Jordan
Killer50stang
632
  • Sep 14, 2005
Jordan
Honeslty, with those mods you should see near 400RWHP depending on the amount of boost you'll be pushing. Read my sig, and I barely spent anything because I went with a carb. Easier to work on...
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 14, 2005
  • Sep 14, 2005
Don't forget new oil pump / shaft. You should also spend an extra 200 to get your rebuilt block balanced.
Daniel50
716
Discovery Bay, CA
Sep 14, 2005
  • Sep 14, 2005
i think you will be able to get 375+ whp out of that setup. you will have to upgrade the tranny if you dont baby it.
bynummustang
Jul 24, 2005
NC State University
Sep 14, 2005
  • Sep 14, 2005
Ok, balance, and rebuild the engine while having it bored over. Should I swap to a forged crank or will the stocker hold up? Of course get a tune, fuel system, new oil pump. Would I need to get a new oil pan as well? What ignition do yall reccomend? Or is that a better question for the KB guys? On the drivetrain side of things...would it beneficail to swap to 31 spline rear axles or a 5-lug set up? Tranny wise, a TKO, or just a world class T-5?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 14, 2005
  • Sep 14, 2005
Don't get ahead of yourself. Have you added up what all that will cost? What does your budget look like? How do they compare? If you want to run a blower and pack in the boost, your going to need a stronger block, much larger heads, intake, exaust, forged internals, this will cost some serous money. Then you need a drivatrain that will hold this and a suspension to get it to the ground. You will need upgrades fuel, suspensiong.... I could go on and on. People get these dreams about having this small list of mods with a small price tag and expect to be running with the big boys, well, it ain't that easy, and it's not anywhere cheap. Then again, you can still build one fast car for not too much money. Before you sign your engine's death warrant first check the compression and leakdown. Go from there.
bynummustang
Jul 24, 2005
NC State University
Sep 14, 2005
  • Sep 14, 2005
I never said anything about budget, but I do have some time to build. I know everything is expensive, and I don't expect to 'run with the big dogs'. After this is done, the car is done. I just want to get the block bored, or bore a different block if compresion isn't up to par, bolt some heads on, and throw the blower on top...oh yeah and the 3 grand in misc. and fuel parts.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Progress Thread BluePrint 347 long block engine swap
  • Sparky714
  • Aug 2, 2024
  • 7 8 9
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 8, 2026
Sparky714
C
331 build power expectations?
  • clayton seiders
  • Sep 5, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2023
FastDriver
