mikestang63
SN Certified Technician
I will pull all 8 tomorrow for a comparison.what do the plugs look like.
s)So that means what then? 5%? 10%, 20% What? A leakdown tester is to accuracy as a Microscope is to a magnifying glass.Leak down test proved that there is equal "blowby" on all 8....
Why rent one when you can build one?The story is I will have to go rent a leakdown tester. I just verified that I have no valve issues with compressed air. that is all.
Not a single store in 50 miles has a leak down tester for that I can rent. And seeing that I'm not paying $60 for something I'm going to use one time I think I'm just going to put new plugs wires on this thing and let it eat. More than likely the fuel in the oil is being caused by the over Rich tune and the excessive cylinder pressures required to make 400 foot pounds of torque (at the wheels) at 2500 rpm.....
So here's what I think I'm going to do I'm going to switch to a copper plug from these iridium plugs and lean the tune out some. I'm also going to recalibrate the wideband and move it into the other header.
Does anyone have a suggestion as to what plug I should run with around 10 PSI boost. I am not buying $8 each spark plugs again.
Just send it to me then, i've got a V6 that you could make very happyMsd super conductor wires
Autolite 103 plugs gapped at .28
New cap/rotor
Car runs so smooth I almost don't want to put the supercharger back on. more idle vacuum
Wierd
Almost.I almost don't want to put the supercharger back on.
