foxstang9050 said:
ok i used the check engine light but im not sure if i
read them right. I think i got 15, 16, and 39. I read them as 15= one blink,
pause, 5 blinks, 16= one blink, pause,6 blinks, then 39= 3 blinks, pause, 9
blinks... am i reading them right?
Code 15 - No Keep Alive Memory power to PCM pin 1 or
bad PCM (Memory Test Failure). The voltage to the Keep
Alive Memory (KAM) is missing (wiring problem) or the KAM
is bad. The KAM holds all of the settings that the
computer "learns" as it operates and all the stored error
codes that are generated as a result of something
malfunctioning while the engine is running. Use a voltmeter
to check the voltage to the pin 1 on the computer - you
should always have 12 volts. No constant 12 volts = bad
wiring. If you do always have the 12 volts, then the KAM is
bad and the computer is faulty.
Note that some aftermarket chips will cause code 15 to
set. Remove the chip, clear the codes and retest.
Before replacing the computer, remove the battery ground
cable for about 20 minutes. This will clear all the codes.
Retest after several days of running. If the 15 code is
gone, then don't worry about it. If it is still there, then you
get to do some troubleshooting.
Wiring diagrams for the proper model years are next…
For 86 models see
http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
For 87 models see
http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
For 88 models see
http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
For 89-90 models see
http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
For 91-93 models see
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
Code 16 - Electronic ignition - IDM circuit fault - Ignition
Systems. Bad wiring, possible bad TFI. The computer isn’t
seeing the proper IDM signal coming from the TFI circuit.
There is a 22,000 ohm resistor in the dark green/ yellow wire
that goes to pin 4 on the computer. Disconnect the TFI
connector and remove the passenger side kick panel.
Then loosen the 10 MM bolt to disconnect the computer
connector. Use an ohmmeter to measure the resistance
between pin 4 and the dark green/ yellow wire on the TFI
connector. You should see 21 - 23 K ohms (21,000-23,000
ohms). If not the dark green/ yellow wire is broken or has a
bad connection. If this checks out OK, measure between
the dark green/ yellow wire and ground. You should see 1 M
Ohm or more, OR an infinite reading. Less that 100 K ohms
means a short to ground somewhere in the dark green/
yellow wire.
Looking at your car year and mods, I can't find a valid
description for a 39 code. They all come up with a
AODE
(Automatic OverDrive Extended) - Transmission Torque
Converter clutch not engaging. You have an
AOD,
and there is no connection between the Automatic
transmission and the computer for your model car.
